Old 05-08-2012, 07:13 PM   #1
HotRodScottsdale
HotRodScottsdale's Avatar
What is this?
i86.photobucket.com/albums/k104/d-2-da-m/20120508_160443.jpg[/IMG]
What is this And what dose it do? It's on a 76 with a 350 small block straight piped
HotRodScottsdale is offline   Reply With Quote
Old 05-08-2012, 07:13 PM   #2
HotRodScottsdale
Re: What is this?
Old 05-08-2012, 07:36 PM   #3
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: What is this?
Was part of the emissions that were removed.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 05-08-2012, 07:44 PM   #4
HotRodScottsdale
Re: What is this?
Should it be flipped any certain way? It's flipped up right now, dose that effect anything? What dose it do inside the pipe?
Old 05-08-2012, 08:11 PM   #5
jame
Re: What is this?
Its the heat riser. It has a butterfly inside that when cold channels warm air through a flexable pipe to the air cleaner. The heat shield has a hole in the top you can see that the pipe would have attached too.
1963 chevy shortstep 327
1965 c60 292
2007 Ram 3500 5.9 cummins
jame is offline   Reply With Quote
Old 05-08-2012, 08:39 PM   #6
RandyP
RandyP's Avatar
Re: What is this?
Had a K5 that had it on there. I took the exhaust loose and removed the piece and blew the butterfly out with a torch and then put the piece back on. They sell a replacement section at the auto parts stores but the blow torch method was free.
Old 05-08-2012, 09:51 PM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
Re: What is this?
here is a close pic
mine fell off the 79 after i took the bolts out lol
I've seen holes drilled/filled to see if it was open or closed before,poke a coat hanger up,holding open tacked from outside
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 05-09-2012, 08:51 AM   #8
East End K5
Re: What is this?
I have the same thing, I removed the valve and thingamabobber that tied into the vacuum line with the carb and bypassed it. I assumed it was part of the A.I.R. (smog) system on my 454. I plan on pulling it all the way out when I do new exhaust. I was thinking it had something to do with the choke as well since it was tied into the carb... I get a kick out of early emissions attempts..
I feel sorry for people who don't drink....because when they wake up in the morning, that's the best they're gonna feel all day long!---Frank Sinatra RIP
[B]1972 Chevrolet K5 Blazer RIP
1986 GMC Sierra K3500 1TON, Long Box, V8350 RIP
1980 Chevy Silverado C30 Cab and Chassis, 454 TH400HD. RIP
[B] 1995 Chevrolet Tahoe 2D [B]
East End K5 is offline   Reply With Quote
Old 05-09-2012, 06:47 PM   #9
Phillip Pennartz
Re: What is this?
That is the heat riser. yours was operated with a vacuum diaphragm. Some earlier ones had a bimetallic spring. Anyway this heat riser when closed forced the exhaust up thru a port in the middle of the exhaust manifold and then thru a passage under the intake manifold exiting thru the other exhaust manifold.
When this is operating right is not a bad thing to have. It helps the motor to warm up faster which helps mileage, emissions and the heater.
The sheet metal part riveted to the middle of the exhaust manifold is the heat stove. When the engine is cold, warm air from around the exhaust manifold is pulled into carb to help with fuel vaporization . Not a bad thing to have either. It helps with cold weather drivable and emissions. When motor is warm this isn't used.
Phillip Pennartz is offline   Reply With Quote
Old 05-10-2012, 01:57 AM   #10
HotRodScottsdale
Re: What is this?
It's a summer truck, never seen snow and No plans too so would it be smart to take out?
Old 05-10-2012, 07:45 AM   #11
RandyP
RandyP's Avatar
Re: What is this?
Since the only thing left is the butterfly piece, there is no sense in leaving it in there. Now if you are wanting to spend a few $100 and buy all the junky emission pieces that have already been removed from your truck and try to make the valve work again, then leave it.
It is probably not hurting anything, but it has zero function right now.
Old 05-10-2012, 08:44 AM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
Re: What is this?
for a summer truck you won't miss it
around here most seem to rust and sieze up,in a bad way, closed
looks a little cleaner I think too
John
Old 05-19-2012, 03:24 PM   #13
paintslinga2010
Re: What is this?
I'm dealing with the same part. Mine is all still intact except i removed the vacuum line. Is it now stuck open or does it need to be wired open?
paintslinga2010 is offline   Reply With Quote
Old 05-19-2012, 05:43 PM   #14
425HP409
425hp409
425HP409's Avatar
Re: What is this?
As Philiip Pennarz stated correctly, this is a "Heat Riser Valve". As it is the open position at this time from the photo you posted, there would be no real value in removing it. If it were to stay in the closed position you would have an exhaust restriction for the right bank. Unless it is rusted stuck, it can be moved by the lever on it. If it is in the closed position and you cannot move it, it would be a good thing to take the exhaust loose and remove wither the flapper valve, or to replace the assembly with a "Dummy Valve" available from the parts store.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 05-19-2012, 07:14 PM   #15
Mrknowitall
Re: What is this?
Another simplistic 70s idea
Lol but really smog requires it to b installed, it was used to heat the engine faster to reduce emmissions upon first startup.
Take an oxy torch to the mechanism if u wanna keep the look without the restriction. But beware here n cali all smog must be retained, hwy patrol can pop ur hood and fine u if alls not there so keep in mind!
Mrknowitall is offline   Reply With Quote
