anybody know these mirrors?
these mirrors are turning out to be hard for me to find! i would like a passenger side to match the driver, but if i got a pair i wouldnt mind. the holes are on the passenger side already but the mirror is missing. what hardare is used to mount? any suggestions/leads? thanks!
1968 C20 450hp 425ft-lbs 454/SM465 4.56's 2004 HD rims, needs paint and a 5th gear! 1969 C30 Open Road Motorhome 350/th400 1972 K10 350/350/205 Daily Driver -SOLD |
Re: anybody know these mirrors?
I was thinking those were just like mine, but I noticed my base mounts are much bigger. You can still have both if you want them
![]() Join Date: May 2010
Those look like the 71-72 style tripod mirrors. The 69-70 style had bigger tripods with the legs several inches farther down the door and the bar to the top of the door turned down where the screw attaches. I have some of each and could post pics in a few days. Also, at least on my 69, the attachment point to the mirror head is offset toward one end whereas all the later style I've seen have it centered.
I just found a picture (attached) of the originals on my 69. The only thing incorrect is that they have a horizontal 6" extension added that GM used to sell. I put the extensions on so I could see around the camper. As I mentioned in my post above, yours look like the original 71-72 style as long as the short horizontal to the top of the door is round with flattened ends.
I also noticed you asked about attachment hardware. They used hex head sheet metal screws. Later GM vans used vinyl or rubber covered well nuts with machine screw threads and stainless hex head bolts (but not hardware store issue). I think you can still get the bolts and well nuts from GM. Just ask them to look up something like a 1977 or 1978 van. |
thanks for the reply! anybody know where i cam get some?
i picked up a set of those a week or so ago off the parts board, just keep an eye there and they will pop up. i also think lmc truck has a set of repros but they have a disclaimer saying they may not fit exactly
1969 c-10 short bed stepside - work in progress ![]() |
