Old 05-09-2012, 06:15 PM   #1
grs
Trouble bench bleeding brakes
I put a new, not rebuilt master cyl. on my 87. I could not get fluid out of the front port while trying to bench bleed it. A shop pressure bleed it. Then it started to leak below the bowl in less then 100 miles. I got another new one. A cardone just like the first one. The same thing is happening. No fluid out of the front. Anyone had this trouble?
grs is offline   Reply With Quote
Old 05-10-2012, 10:24 AM   #2
Desert1957
Desert1957's Avatar
Re: Trouble bench bleeding brakes
make sure you are using lines back into the reservoir while bleeding (bench bleeding kit), one other tip is there are two stages. You might not be pushing the piston in far enough for the front to flow fluid.
Here is a good video with an explanation of what's going on.
Desert
Desert1957 is offline   Reply With Quote
Old 05-10-2012, 05:08 PM   #3
grs
Dual Brake Master Cylinder - How to Bench Bleed (Moss Motors Tech) - YouTube
Desert
Thanks. The front may be OK now. But the rear keeps getting bubbles not out of the tube, but from the bottom of the tank in the rear section.
