Old 05-10-2012, 10:15 AM   #1
Del72Chevy
Del72Chevy's Avatar
Does dash come out of cab? 72
On a 72 does the dash come out of the cab or is it all one piece with the cab? The PO cut a big old sloppy hole to put his aftermarket tape player in and you can see a gap almost all the way around it so I was gonna try to replace the dash an try to put back in an original looking radio. Or if this is not an option does anyone sell sheet metal that can be welded in for the radio section to go back to the one small hole with the two round holes?
Del72Chevy is offline   Reply With Quote
Old 05-10-2012, 10:35 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Does dash come out of cab? 72
It can come out with a lot of effort. Bolts on either side and tons of spot welds that have to be drilled out from around the bottom of front windshield - which has to be removed.
Another possibility that some guys have talked about is cutting it with a cutoff tool under the front pad area and then rewelding. Either way, it does take some work.
68gmsee is offline   Reply With Quote
Old 05-10-2012, 02:33 PM   #3
RenoKeene
Florida Edition
RenoKeene's Avatar
Here is the short version:
take off the dash pad, guage cluster and glove box door. Take your cutoff wheel and cut along the slots where the dash pad was, one cut under the cluster hole and one under the glove box door. Remove and throw it in the scrape pile. Post a WTB dash center section add in the parts forum. When you get your new piece weld it in and re-assemble.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 05-10-2012, 02:55 PM   #4
72GMCK-2500
72GMCK-2500's Avatar
Randy (Teeitup) has lots of the dash centers cut out. You should get ahold of him and grab one up!
1947 Chev 3600, 454,th350,9"ford tubbed (Pop's ride)
1965 GMC 1000 305E V6, Powerglide. GONE
1972 GMC K-2500 350, 4 speed, 229,000 miles
1988 Chevrolet Caprice 9C1 Ex cop car, 350, 700r4.
1997 Ford F-350 4x4 XLT (The Hauler) 7.3 diesel.
RUST NEVER SLEEPS
72GMCK-2500 is offline   Reply With Quote
