Old 05-10-2012, 01:53 PM   #1
c10327
c10327's Avatar
streeing conversion
I have a 1970 c10 that came with manual steering an having an issue with pit man arms ? the manual Pittman arm wouldn't fit the new power steering box as the splines shaft was different . so I bought a power steering pit arm an it fits the new box but now were it bolts to the drag link the shaft is different size than the old manual shaft . the shaft is a little to small to tighten up properly ? do the make a shim or is the another pit arm for this kinda swap ?? any help would be great
c10327 is online now Report Post Reply With Quote
c10327 is offline   Reply With Quote
Old 05-10-2012, 03:06 PM   #2
Tinkermc
Re: streeing conversion
I wish I knew since on my 67 I plan on doing the same swap
Tinkermc is offline   Reply With Quote
Old 05-10-2012, 05:15 PM   #3
c10327
c10327's Avatar
I bought the ps steering box at advance auto parts an the new pit arm there as well both parts were looked up for my 1970 chevy c10 2wd .. I will try to post pic's of the 2 pit arms to show the diffrence , someone out there has had to run into this issue doing a conversion ?
