Old 05-10-2012, 05:17 PM   #1
Wincks2
Reversing towing wheelbase rule of thumb?
There is a towing wheel base rule thumb that a 110" wheelbase can tow a 20' trailer and then you can add 1' of trailer for each additional 4" of wheelbase.
I have a 4,000 lb camping trailer that is 16'6" from bumper to tongue hitch. Is it safe to reverse the rule of thumb and conclude that:
20' - 3' = 17'
So 110" wheelbase - (3' x 4") = 98" wheelbase would suffice.
Which means I could tow my trailer safely with a Blazer which, I think, have wheelbases of around 104".
Does this seem safe?
Old Smokey: 85 GMC 3/4 ton long bed crew cab originally a 5.7 gas engine now with an 84 6.2 with a 92 serpentine belt system, a banks sidewinder, torque converter, and a shift kit. I bought her this way from someone handy - and now am trying to figure out how all this truck works.
The Old Smokey project: http://67-72chevytrucks.com/vboard/s...d.php?t=390518
Wincks2 is offline   Reply With Quote
Old 05-10-2012, 09:46 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Reversing towing wheelbase rule of thumb?
I've had a few and towed with them a good bit. There's no making up for that short wheelbase, 1.5 inches shorter than a 79 Z28. It will push if you brake too hard and it will whip if you change lanes too quick. Drive with that in mind and it'll do OK at that length.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 05-11-2012, 02:20 PM   #3
Wincks2
Ok. Thanks. Sounds like in an ideal situation I'd havea blazer that was a little longer.
Old 05-13-2012, 12:17 PM   #4
misternash2
im generally pretty ignorant about squares, although i love em. i don't know what the wheelbases are, etc.
i towed my 18' bass boat, which probably has near a 20' trailer. it's an 88 ranger which isn't known to be light. it has a 175 johnson on it. i don't know what it weighs. my 85 shortbed pulled it great! it didn't seem to push bad, although it did sway a little. i blamed that for the heavy outboard over the back of the trailer though. to be fair, i drive pretty conservatively. i don't accelerate or brake real hard. (well, okay. i accelerate hard every now and then, but not pulling the boat!)
misternash2 is offline   Reply With Quote
Old 05-13-2012, 03:45 PM   #5
68Timber
68Timber's Avatar
That short-box pickup has 11" more wheelbase, too.
John
74 Honda Z50 build
Old 05-13-2012, 03:58 PM   #6
misternash2
wow, 11 inches is a lot. i never realized there was that much more! i'd have guessed a few at most!
Old 05-13-2012, 10:02 PM   #7
Ford Assassin
Ford Assassin's Avatar
I own a 1976 20' Komfort Travel Trailer that I tow with my K5 often. I have no idea how much it weighs, but its at least 4000+ lbs. I am running a Class III hitch with a digital trailer brake controller. I have ZERO issues with sway or 'pushing', even with a 20 mph crosswind.
I am converting to 2wd right now and considering added a sway-control type attactment, but I'll wait until I have problems before fixing a problem I don't have.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
