05-10-2012, 10:57 PM | #1 |
Bags airing up uneven
I have 91 suburban with bags on the front. Just recently the passanger side bag looks like it has less pressure? Ive parked on even ground and checked it I've aired them out all the way and re-inflated and still having the same problem. Why am I uneven!?
Posted via Mobile Device |
05-10-2012, 10:58 PM | #2 |
67-72 parts collector,…
Re: Bags airing up uneven
Do you have separate lines to each bag?
Or 1 line with a tee in it?
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 05-10-2012 at 11:12 PM. |
05-10-2012, 11:06 PM | #3 |
Have Schrader valve to Tee to bags...
05-10-2012, 11:11 PM | #4 |
VA72C10
you'll need two schrader valves....the T is allowing air to transfer...it would be worse when driving...
Looking for a 67-72 swb or blazer project in or around VA. |
05-10-2012, 11:28 PM | #5 |
But I've had it hooked up like this for about 5 months with no problems?
05-11-2012, 01:40 AM | #6 |
VA72C10
You lucked out then for 5 months...
If you still want to keep the one fill point add a ball valve between one or both of the lines from the T to the bags...open it when filling it then close it so the air can't transfer once the air pressure evens out.....
05-11-2012, 01:47 AM | #7 |
That's the bad thing about a T... air is free to move from bag to bag.
Bryan (Redneck) '66 Chevy Longbed Fleetside '12 Dodge Ram 3500 '08 BigDog Pitbull '11 Cargomate Trailer (Toy Hauler) |
05-11-2012, 07:40 PM | #8 | |
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
05-11-2012, 07:56 PM | #9 |
Hahaa I need one!!!
