Old 05-11-2012, 01:35 AM   #1
vectorit
What?
vectorit's Avatar
Steering gear boxes
OK here is the deal... I just acquired a matched set of axles from a '72 K20 for my burb, and the open knuckle disc brake D44 has power steering components. While my current closed knuckle D44 is set up for manual steering gear box.
So can I still use my manual steering gear box with this new old open knuckle disc brake D44?
If I can continue to use my manual gear box after upgrading the axle, that would be good for my budget and time. Plus converting to power steering on a 1968 K20 will require an adapter, since the frame is flat sided and a power steering box requires the dimples to install hence requiring an adapter.
Personally I don't mind the manual steering set up, so if I can plan that as a later upgrade project all the better.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 05-11-2012, 09:56 AM   #2
Burt4x4
Burt4x4's Avatar
Re: Steering gear boxes
Sure I would think that work fine as long as your current steering componets connect up the same = draglink..the axel won't care were the input is coming from as long as it doesn't bind..
.025c
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
