05-11-2012, 02:11 AM | #1 |
Melted fan switch plug
Where can I buy a new fan switch plug for a/c or the parts to make up a new one? I guess finding a used one is tough because it is a fairly common problem. I appreciate any help. Thanks.
05-11-2012, 02:31 AM | #2 |
Old member
Re: Melted fan switch plug
05-11-2012, 02:48 AM | #3 |
Not sure what it is supposed to look like. Mine was fried and PO Rube Goldberged it. Switch has 3 male spade terminals in a row and 1 off to the side.
05-11-2012, 04:28 AM | #4 |
Old member
This is the fan switch for heat only.
Can't find a heater only connector though. Sorry!
05-11-2012, 05:18 AM | #5 |
Doesn't look like that. I need a plug for an a/c switch.
05-11-2012, 07:03 PM | #6 |
Old member
Then it's the first picture I posted. That is the connector it doesn't come with crimp connections you use the old ones are make new ones.
05-12-2012, 03:12 PM | #7 |
Thanks for help the Andy. I appreciate it!
