Old 05-11-2012, 01:19 PM   #1
x1buellist
x1buellist's Avatar
Stepside fender support brackets
I am looking at replacement fender support braces. I see them listed on a couple sites but they are different than what I see on my 66 stepside truck. I have a brace that connects the fender to the frame. Where it attaches to the frame it is threaded and goes through the frame with a nut on each side. The ones they sell look to have eyelets instead of threads. Maybe mine are not original or correct. Anyone know which is correct?
x1buellist is offline   Reply With Quote
Old 05-11-2012, 01:30 PM   #2
1963c-10
1963c-10's Avatar
Re: Stepside fender support brackets
The threaded ones are original and use bolts to mount. The repops use nuts and bolts and the ones I have seen do not have the threaded ends.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-11-2012, 01:32 PM   #3
1963c-10
1963c-10's Avatar
The replacements look like these, but there are 6 total for stepsides. Fleetsides have 4.
Old 05-11-2012, 01:45 PM   #4
x1buellist
x1buellist's Avatar
yeah exactly, thats what the replacement looks like but thats not the same as the ones on my truck. Well atleast thats not the same as one on each side that has a threaded end not an eyelet.
Old 05-11-2012, 02:14 PM   #5
1963c-10
1963c-10's Avatar
Are you looking for a set or just one of the long or short ones?
Old 05-11-2012, 04:09 PM   #6
x1buellist
x1buellist's Avatar
I actually would like to get the threaded supports but would buy the set if it included the ones I need.
Old 05-12-2012, 12:47 AM   #7
Trap62
Trap62's Avatar
http://www.classicparts.com/1955-59-...nfo/37%2D885S/
The above link is for a threaded brace for the 55-59 chevy truck. Not sure if they are interchangable. I'm in the same boat in needing to replace one that is broken.
Trap62 is offline   Reply With Quote
Old 05-12-2012, 12:52 AM   #8
x1buellist
x1buellist's Avatar
that definetly looks like it but I would have to assume they would list it as for 60-66 if it worked. Kinda weird how no one seems to have this part.
Old 05-14-2012, 08:44 AM   #9
1963c-10
1963c-10's Avatar
The rear fenders on the 2 nd series 55 -66 were the same, so I would think the rods would fit with no issue. Come to think of it, my fender mount spare came off a late 50's stepside and the rods came with it and were used when I did the conversion.
Old 05-14-2012, 09:08 PM   #10
x1buellist
x1buellist's Avatar
That sounds right. I think I'll get them
Old 08-11-2013, 06:19 PM   #11
1963chev
1963chev's Avatar
Re: Fleetside! Stepside fender support brackets
Bump. I was searching for info on rear fender supports for my SWB Fleetside and found this thread. Any further info on how the after market ones fit? Are they hollow tubes? Any one out there try to make their own out of some 1/4 inch rod stock? Or have other info on them cheaper than $80 bucks? Thanks
1963chev is offline   Reply With Quote
Old 08-12-2013, 08:47 AM   #12
1963c-10
1963c-10's Avatar
They should all be solid steel.
