05-11-2012, 01:55 PM | #1 |
C/10 junkie
What are you guys using for needle paint??
I bought some off eBay and even though the color looks good it doesn't cover well. I leaves steaks. What brand and where do you get it?
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
05-11-2012, 02:50 PM | #2 |
Junior Member
Re: What are you guys using for needle paint??
I like to use Testors Fluorescent Orange from the model hobby section. It's the brightest I've found and has that flat sheen. Are you spraying or brushing? I found spray can rather than brush leaves a more even coat.
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
05-11-2012, 03:26 PM | #3 |
I don't brush paint, what I use is a spray bomb in either an (bright) Orange marker paint, Chevy orange, or something with a little more red in it.
Then, after painting a spray them with a clear coat- gloss spray paint. The way to mask the gauge is to take a piece of paper (newspaper) about 2-3" bigger than the gauge face. The razor knife one single slice/cut from one side to the very centre of the paper. Then slide that up/under the needle stem. When it is seated on the centre of the needle take a piece of masking tape and tape the single slide/cut so no overspray sneaks in. Then spray away and whe done you can cut or carefully rip the tap/paper off. No adhesive touches the face of the gauge or the needle this way. My two bits. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
05-11-2012, 03:37 PM | #4 |
C/10 junkie
That sounds like some good ideas. Are these colors the same as the original?
05-11-2012, 06:36 PM | #5 |
C/10 junkie
ttt
05-12-2012, 10:34 AM | #6 |
I used some flouresent orange krylon. Works and looks great! I also brushed in the temp gauge.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
05-12-2012, 10:40 AM | #7 |
C/10 junkie
That does look really good, thanks for the tip.
05-12-2012, 09:08 PM | #8 |
Oh paint! I thought this was a thread about needle point.
05-12-2012, 09:20 PM | #9 |
C/10 junkie
Tim you crack me up. Feel free to show us some of your finer needle point.
05-13-2012, 12:17 AM | #10 |
I used fingernail polish it may not be factory original but close enough and i like it
05-13-2012, 10:11 AM | #11 |
I used a brand called Model Master, fluorescent red that I got from the local hobby store. I used a brush and applied 2 coats.
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
05-13-2012, 11:29 AM | #12 |
05-13-2012, 11:42 AM | #13 |
C/10 junkie
they were BBQ to boot.
05-13-2012, 02:32 PM | #14 |
I used a Valspar product in their Odds 'N' Ends line (small hobby size spray cans) called Orange glow #140S. What I like about it is that the color is close to original and it's also a satin or semi-flat finish close to the original. I think the only needles I sprayed in the pic are the speedo, tach, fuel and temp gauges.
Since I posted this I tried to find the product online. No luck. It seems it may be a Plasti Kote product with the Valspar name. Last edited by FirstOwner69; 05-13-2012 at 02:57 PM. |
05-13-2012, 08:46 PM | #15 |
Needle paint? It's been so long since I've restored a truck I don't even remember exactly what I used (should make records of this stuff). I leave stuff like this these days to our resident dash restoration expert,PT'S 70 CST . Actually,I'd repaint a needle,but gauge restoration is what I'm talkin' about.
05-13-2012, 08:59 PM | #16 |
I just went to advanced auto and bought a touch up paint pen/brush in torch red and hit up the gauges
BEFORE: During: After:
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
05-13-2012, 09:10 PM | #17 |
How do people go about masking the tach needle? My biggest concern is trying to match the orange of the tach because it looks like a bear to properly mask and paint, but if there's a trick that makes it easier, let me know!
05-13-2012, 09:12 PM | #18 |
I just fold a paper towel so there is 2 layers and poke a hole into it...Slip it over the needle and rip it over the big part and try to stuff it under it a bit..Only used 1 layer in the above pic..No problems but afterwards looking at the bottom i got a little lucky
05-13-2012, 09:33 PM | #19 |
GM ONLY BABY!!!
Testors model paint applied with a brush worked great for me.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
05-13-2012, 09:35 PM | #20 | |
Jim |
05-13-2012, 09:38 PM | #21 |
GM ONLY BABY!!!
No masking needed if you use a brush.
05-13-2012, 10:10 PM | #22 |
05-13-2012, 11:11 PM | #23 |
I used a brush...still needed masking..Key with the brush is to dont stroke it too many times
05-14-2012, 10:43 AM | #24 |
Moderator
This is what I use.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
05-14-2012, 10:47 AM | #25 |
C/10 junkie
I kinda was thinking the same thing as well. Put it on thick and let it flow.
