Old 05-11-2012, 02:33 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
wilwood master cylinder which one?
I notice that a lot of guys are running these with out a booster? How well does that work? I have stock drum rear and disk front right now but would like to upgrade in the future.. Which wilwood unit would I want what bore? I also know that I need a portioning valve also any recommendations?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-11-2012, 07:58 PM   #2
Scottshotrods
Re: wilwood master cylinder which one?
On your set up you would want to go with the Wilwood manual master and your bore size you want to run is a 1 inch bore.You want to run a Wilwood adj prop valve.I would add a 10 lb res valve for the rear drum brakes.Your factory brake pedal will work very good with this set up.On the firewall you will have fill the hole in to install the master on in place.
If you need these parts we have them all in stock.
Justin
(805) 485-0382
www.scottshotrods.com
Scottshotrods is offline   Reply With Quote
Old 05-13-2012, 10:55 PM   #3
RdoubleU
RdoubleU's Avatar
This might help:http://67-72chevytrucks.com/vboard/s...d.php?t=511378
I had the same questions and got some answers
Best thing you can do to be sure is call Wilwood and their tech group will tell you the best application for you
RdoubleU is offline   Reply With Quote
Old 05-14-2012, 03:01 AM   #4
weekendracer728
weekendracer728's Avatar
Dont waste your money on wilwood. Dont get me wrong, they are nice. But for a good master-run a stock 7/8 bore from a '76 monza. I just order one and will b running this cause I hate boosters.
Live life one weld at a time.
'04.5 Chev Duramax CCLB- Winter DD
'03 Grand Prix GT- Summer DD
'67 C10-307/T5(For Now)-R.I.P-Burned Up!
'68 C10-5.3/4L80E
www.one-guys-garage.com
weekendracer728 is offline   Reply With Quote
Old 05-24-2012, 09:21 AM   #5
FRENCHBLUE72
PROJECT 7DEUCE
Hey justin can you shoot me a pm with pricing on these items....Ill try to give ya a call friday when im back in town..
MEMBER #6377
Project "7DEUCE"
Old 05-24-2012, 11:22 AM   #6
Scottshotrods
P/m sent
Justin
