05-11-2012, 10:20 PM | #1 |
Radiator support bushings
Hey guys,
I'm about to order a body mount and bushing kit. My question is this...my chassis is a '69 GMC, the front clip is a '68 Chevy. Do I need to purchase a kit for the '67-'68, or the '69-'72 truck? Seems like I remember reading a post on here about the core support mounting points for the '67-'68 were "below" the top of the frame rail and the '69-'72 were level with the top of the frame rails. Any input would be greatly appreciated! Danny |
05-11-2012, 10:32 PM | #2 |
Re: Radiator support bushings
My 68 is flush with the top of the frame, (the core support stand) making them the thinner set of bushings.
I believe the later ones are lower than the frame rail. |
05-11-2012, 11:58 PM | #3 |
Here's a link to the previous thread you mentioned in post #1.
http://67-72chevytrucks.com/vboard/s...d.php?t=463993 |
05-12-2012, 05:57 AM | #4 |
Still plays with trucks
Does anybody know how tall the mounts between the core support and the frame mount brackets are supposed to be for the 67-68? Mine were so rotten they are worthless to measure.
On my 67 I opened up the hole size in the core support brackets on the frame to the larger diameter that the 69-72 C10's used so I could use the polyurethane mounts. I just haven't gotten the cab back on yet so I can align the front clip & see how things line up. I will machine the poly core support bushings down in height to match the correct dimension for a 67-68 if needed so my front clip fits properly.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
