Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 05-12-2012, 10:04 AM   #1
Lower
Lower's Avatar
Building my shop soon.
Here is a sketch of how im going to lay it out. Looking for suggestions to what you guys think. Its going to be a 30X40X12 with two 10X10 overheads. Its drawn to scale. each line is 2ft
~Jon
Ol Green 1970 K10ish LWB,454/400/205, been in family since new.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=516056
Lower is offline   Reply With Quote
Old 05-12-2012, 11:35 AM   #2
beautimus
beautimus's Avatar
Re: Building my shop soon.
looks like a nice shop, !
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 05-12-2012, 11:40 AM   #3
BarryB
BarryB's Avatar
Looks like a good plan, If it were me though. I would move the lift over to be in front of the other door. reason Gives you more room in front of the bench. For when you have a motor torn apart or something with alot of parts.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 05-12-2012, 11:46 AM   #4
fine69
fine69's Avatar
I would move the doors over a little farther. And leave some space between them. So if you have two vehicles you can really open the doors.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 05-12-2012, 11:56 AM   #5
cayoterun
Junior Member
cayoterun's Avatar
Great size and plan:
I've found you can never have the doors too wide or high. Most of all the overhead.
I've froze my rear off 6" from a warm heater, because I had something 6" too high to clear the overhead.
Cayoterun
Cayoterun
Okla. Panhandle
I think I'll do it myself and pay the extra $500.
cayoterun is offline   Reply With Quote
Old 05-12-2012, 12:16 PM   #6
jfortvalley
i would go about 2 ft higher to 14 ft with the lift it comes close with a truck with a camper shell on the lift . put work bench at the back of the shop helps with room .
jfortvalley is offline   Reply With Quote
Old 05-12-2012, 01:13 PM   #7
GOPAPA
GOPAPA's Avatar
My first thought was this what fine 69 says,, it's hard to move a car over once in the shop due to the sharp turning.. lots of going forward and backing up..
nice size shop and I like the room you have ( 7 ') from car to work bench,,I realize you lose some with the car door open but ,,to get more room for that you'd have to build a bigger shop..and that cost more $$ and more room on property to do so.. JMO thought as I see it ..
When you learn a thing a day you store up smart.
GOPAPA is offline   Reply With Quote
Old 05-12-2012, 07:47 PM   #8
CoggedBelt75
CoggedBelt75's Avatar
That's going to be one nice shop. I agree with the others about the doors needing more separation. Moving the 1st one further to the left will make things easier with 2 vehicles in at the same time. No matter how you go about doing it, it sure beats my dinky 1 car garage.
Joe
__________________________________________
1975 C10
"Questions are a sign of intelligence indicating a desire to eliminate ignorance"
CoggedBelt75 is offline   Reply With Quote
Old 05-13-2012, 03:12 PM   #9
Lower
Lower's Avatar
I want the door next to the bench to stay, beings that its a wooden shop I got to make sure he can move the doors over. the posts are on 10ft centers but im not sure if he can put a header in to move them to where I want them, 5ft between the doors. The two post lift in my buddies shop is just shy of 11ft tall across the top brace, cant raise anything higher than the safety stop anyway. If i moved the lift over to the other door and had something parked in there I would have to walk around it to get to the bench, which is why I like it there. The bench across the back would work ok but it quickly takes up alot of room when its only going to be 30ft deep.
Keep the suggestions coming in though, I know there are some good ideas that im overlooking for the rest of the layout.
~Jon
My build thread
Old 05-13-2012, 03:44 PM   #10
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
12 foot wall is nice, what is the pitch of the roof? put some good fans in the ends to help with air movement. Ditto on the overhead doors. Your builder should be able to move the doors around where you need them even with a pole barn.
3 foot deep workbench will be nice.
low'n slow is offline   Reply With Quote
Old 05-13-2012, 07:02 PM   #11
BarryB
BarryB's Avatar
how about this, instead of using your standard A framed roof truss. Use scissor trusses over the span where your lift shall be. You'll gain some height (depending on roof pitch) so you have the option to go higher with a lift. without raising your walls higher.
Two rules in life.
Old 05-13-2012, 08:29 PM   #12
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
On your sketch,the bottom left side,straight across from the man door,at the very back,put another roll up door even if it's a small one.When it's warm it will help with airflow thru the shop.That will help keep it cooler and less smoky when welding or running an engine.Put a small lean-to with a pad for the Air Compressor.If you use the scizzors truss,put in skylights,since you wont have loft storage.If you can run water do.You can use a utility sink for both parts cleaning and Jon cleaning(keeps momma happier if you don't drag grease etc into the house),a half bath is even nicer.Wire a seperate main elect box for the shop.
Just things I would try to do if I build.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-13-2012, 09:14 PM   #13
rstewart09
rstewart09's Avatar
That is the same size as mine. I put the doors 8 ft from each side with 4 ft between them. That lets me park a truck against the wall and still pull in another through the open door. I thought the 10x10 doors where great till I bought a toy hauler that is 10' 6" to the top of the air conditioner. Oh well there is always too much stuff in there to put it in any way. I have plans for a lift also but still have not done it. I am now leaning to a 4 post lift with wheels so I can move it from side to side.
The start of a new toy
1967 GMC 3/4 ton
rstewart09 is offline   Reply With Quote
Old 05-13-2012, 09:46 PM   #14
rstewart09
rstewart09's Avatar
Here are a few pictures of mine.
Was just finished.
The first occupants.
As other things moved in.
1967 GMC 3/4 ton
Old 05-13-2012, 09:51 PM   #15
TennesseeZ
Countdown Survivor
TennesseeZ's Avatar
Lots of good info at Garage Journal
93 Yukon
89 Silverado Z71 SWB Sport
91 K 2500 Silverado "Lobuk-Worktruk"
A MAN OF HONOR DOES NOT LIE, CHEAT, OR STEAL, NOR TOLERATE THOSE WHO DO.
Gettin' old ain't for sissies.
TennesseeZ is offline   Reply With Quote
Old 05-14-2012, 02:11 AM   #16
YBNORML
YBNORML's Avatar
The one thing that I would make sure to do if I was you is to try and figure out where you would like to put overhead shelves. Then install plenty of backing in the walls. We all tend to overload whatever shelving we put up!
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 05-14-2012, 09:52 AM   #17
Mudder
Mudder's Avatar
Mine is just going on two years old and it is packed. I live in town so I was linited on size and size dooes matter. Thing that get me is how all this stuff that don't belong to me ends up in there.
Mudder is offline   Reply With Quote
Old 05-14-2012, 12:49 PM   #18
C/10 King
C/10 King's Avatar
You're going to love it once it's done! there's nothing like a big giant toy box!
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 05-14-2012, 02:23 PM   #19
jame
Like a few others have mentioned frame now for as large of a door as you can. I just built a 30x40 with 2 10' tall 12' wide doors. Even if just one of the doors is wider it wil look fine and allow one bay to be more user friendly. I can tell you one dually fender more than pays for the increased header size cost needed to span 2' extra.
1963 chevy shortstep 327
1965 c60 292
2007 Ram 3500 5.9 cummins
jame is offline   Reply With Quote
Old 05-15-2012, 01:04 AM   #20
rambler
MOVE OVER
rambler's Avatar
I have to clean mine out, its so full of stuff, cant even pull in there anymore...
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
