![]() Join Date: Apr 2012
Who sells rear drop springs for Chevy suburban ?
Who sells rear drop springs for Chevy suburban I called Cpp and Ec they don't ?
Posted via Mobile Device |
![]() Join Date: Oct 2004
Re: Who sells rear drop springs for Chevy suburban ?
CPP sells heavy duty 4" drop rear coils for suburbans and panels.
Part# RCS603-4HD |
do you know if they sell 5'' ?
If you go 5 you will need to "C notch" the frame and also make sure you have a slider driveshaft or you will eat up center driveshaft bearings like crazy.
ok thanks
mine does not have a slip joint in it ?
im wanting to lower it 5.5 x 7 ? |
Thanks I got my parts ordered
How did those springs work out for you ?
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile* 1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig. http://67-72chevytrucks.com/gallery/...=74049&cat=500 |
They worked out good I bought them from pol but I wish someone would have told me to get a stiffer spring in the front to I had to put a 2" spring in the front to get it were I wanted it 5" 7" thanks
BlahBlahBlah
What size rims are you running?
I didn`t see a heavy duty drop spring on POL website, do you have a part number of the one you used? Thanks.
Junior Member
Glad I saw this I have a set of 4" truck springs and a set of 6" and I WAS going to try the 6" springs first.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
| Bookmarks |
