05-12-2012, 01:06 PM | #1 |
Building '68 GMC K20.
Hi, im new to the 4x4 world and im jumping in all at once. Im changing the axles to the later '78s dana 44 and 14 bolt. I know the dana will bolt right up and was wanting advice on the powersteering. Will the box off the '78 bolt up to my truck? And also what advice can i get on installing the 14 bolt. It looks like i need to change the spring mount on the axle. it looks to be wider on the 14 bolt or should i change to the later spring mounts and later springs?
Thanks and have a great day... |
05-12-2012, 01:18 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: Building '68 GMC K20.
dude, you cant do that! we need pictures of your ride before we can answer any questions!
ok, thats not really true, but i would like to see picture! im no good to answer your questions though, but you will find alot of helpful folks here
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-12-2012, 01:38 PM | #3 |
The Older Generation
I can't answer your 4x4 questions either but welcome to the board!! Someone on here will be able to give you the skinny on this.... LockDoc
05-12-2012, 01:49 PM | #4 |
Currently Blazerless
Welcome to the board!! As far as the steering gear box goes you can still use your original, if you want to use the 78 it will bolt up just fine but you may want to get the power steering pump from the 78 also as this was about the time they went from a flare fitting to an O ring style. On the rear your much better off just moving your spring mounts on the axle....and you will have to move shock mounts as well as they are staggered on the 73 up trucks..still a much easier job than moving springs!
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
05-12-2012, 02:04 PM | #5 |
What was wrong with the running gear under your K20? was it broke? I have a '68 K20 stepper and can't imagine wanting to remove that classic closed knuckle running gear
I did not know that PS was an option for 3/4 tons in 1968, but I learn something new every day around here. ...yup, you gotta post some pics.... |
05-12-2012, 04:58 PM | #6 |
Well thanks guys. I will get some pics up as soon as i can. No my stock running gear is fine but im wanting to make it my daily shop truck and i would like to have the bigger brakes plus the disc up front would be a plus too. And it has the 4.56 gears that arent highway friendly. I well be saling the stock axles and the lockouts too that are i believe stock. Oh and no this one doesnt has power steering. I would just like to add it...
05-12-2012, 05:11 PM | #7 |
Sorry I didn't notice this was for a 68. The later gear box will work but you may have to dimple the frame or make some spacers, I know some guys have used the frame reinforcing plates to mount the box, either way it's worth the work envolved. I agree nothing wrong with the stock setup but power steering and disc brakes make a Big difference on a daily driver.
05-12-2012, 05:11 PM | #8 |
I just did get some pics up. I would like to find out the HP rating on this. It has the 327cid with the rochester 4barrel. I have heard it was from 275hp to as much as 350hp???????
05-12-2012, 05:15 PM | #9 |
Thanks Blazerman. I thought the frame was alittle diffrent bu i do have the front frame horn off the truck i parted. Ill use it for the pattern.
05-12-2012, 05:24 PM | #10 |
What?
I am in the process of upgrading my old axles to D60 and open knuckle disc D44, and to put your PS gear box on you need an adapter. I don't recommend doing the torch and hammer routine on your frame, it will just weaken that area and that is a high stress part of the frame. I plan to use an adapter from "Captainfab" for my PS steering gear. Here is a link to some of his stuff. http://www.67-72chevytrucks.com/vboa...d.php?t=332923
Chris 1968 K20 Suburban 1972 K10 LWB PU |
05-12-2012, 05:32 PM | #11 |
Thanks vectorit, I will check it out.
05-12-2012, 05:46 PM | #12 |
Oh and something else im wondering about is that my rear springs are 3" wide and all im seeing are 2.5" wide on the new pad mounts. Will this be a problem?
05-12-2012, 05:48 PM | #13 | |
05-12-2012, 05:49 PM | #14 |
Yep it sure does. Would make it alot easier to just bolt it on and go...
05-12-2012, 06:12 PM | #15 |
Hey Hotrod 4x4 ...
to the forum and from Ohio. Glad to have you on board and yes...we luv pics !
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
05-12-2012, 06:26 PM | #16 |
Thanks 70cst... Ill try to add more pics as i do the build...
05-12-2012, 07:17 PM | #17 |
A K20 GMC......where did you find one of those? I have never seen one before. Maybe it has the rare Corvette package?
05-12-2012, 08:56 PM | #18 |
Yeah it could be. I would like to find out what it is for sure...
