Old 05-12-2012, 04:56 PM   #1
71blazervt
carb question
This carb is missing the little tag. Does anyone one know which one it is to order/buy a rebuild kit.
71blazervt is offline   Reply With Quote
Old 05-13-2012, 12:06 AM   #2
old man jimmy
Re: carb question
i haven't been around a 2 barrel for many years. but it should be either a carter or rochester. look for a 7 numbers stamped on it somewhere. usually on the base plate. that should be all you need to get a kit for it.
old man jimmy is offline   Reply With Quote
Old 05-13-2012, 11:32 AM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: carb question
What engine do you have?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 05-13-2012, 01:23 PM   #4
71blazervt
Re: carb question
found it jimmy, thanks. 7041105
Old 05-14-2012, 03:11 AM   #5
old man jimmy
Re: carb question
you're very welcome. Just thought i'd add.. if it still has the original brass float, check it real good. they have a tendency to leak on that carb and pump gas into the oil.. not a good thing. seen more than one rounded cams on 307's with that set up.
