Old 05-12-2012, 09:34 PM   #1
hugger6933
6 CYL power steering brackets
I know very little about the 6 or the 60-66 model trucks. I need to know a little info about my C60, it has a 292? in it and I would like to add power steering . What models can I look for to get the pump and brackets and pulleys off of? what all years will fit and what all motors will fit as well [ie250] Thanks for the help. I am pretty sure I can find a C40-60 power steering box off something ,won't they work for like a hundred years? I had mine given to me by my bro in law and they [his family ]farm bought it new it has 29,000 miles and the dump still works as it should . The front grille is smashed a long with the hood and grille surround and left fender. I am gonna go in search for these parts soon. All of the lights even work. The only problem is the rear wheel cyl on the right rear is leaking and will need to be replaced. I will be using this at my body shop and throwing scrap metal on it and when it is loaded I'll take it off to the yard ,easier than loading a trailer and I can move it out of the way and load whenever. So thanks for looking and thanks for helping if you can
hugger6933 is offline   Reply With Quote
Old 05-12-2012, 11:50 PM   #2
Captainfab
60-66 Nut
Re: 6 CYL power steering brackets
You will need the pump brackets and pulleys from another 292. The brackets from a 250 are different, but I believe you may be able to make them work if need be. Another option is that there is a seller on ebay that manufactures new PS pump brackets for most GM I6's including the 292.
Old 05-13-2012, 12:44 AM   #3
pestwagon
Please note that you must be a supporting member to post classified item. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
pestwagon is offline   Reply With Quote
Old 07-04-2012, 11:59 AM   #4
factorystock
factorystock's Avatar
This looks like the correct set up for earlier 292. You might need to also find a crankshaft pulley with double grooves.http://www.ebay.com/itm/292-Chevy-GM...493b73&vxp=mtr
factorystock is offline   Reply With Quote
Old 07-04-2012, 02:05 PM   #5
65chev
This is the bracket from ebay vendor. Nice product, well made.
Mike
65chev is offline   Reply With Quote
Old 07-04-2012, 09:56 PM   #6
hugger6933
That is a really nice looking product. Nice looking motor you have there different than all of the v-8's[that I love!!]
Old 07-04-2012, 11:12 PM   #7
1972RedNeck
1972RedNeck's Avatar
Mike
Who did you get it from?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 07-05-2012, 12:42 AM   #8
65chev
Davis speed equipment. Look under 292 chevrolet on ebay.
mike
Old 07-05-2012, 02:05 AM   #9
70cst
70cst's Avatar
WOW that truck is a beast but I like it
Best of luck fixing it up ...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 07-05-2012, 06:25 PM   #10
65chev
Another alt/power steering pump system
http://www.ecihotrodbrakes.com/
Mike
Old 07-05-2012, 10:21 PM   #11
brap999
brap999's Avatar
I second the Davis Engineering brackets off eBay. I use it on my 230 and it was hands down easy to install, it was adjustable so I was able to make the pump line up perfectly with the other pulley. Like someone else said, he makes them for the 292 as well.
I had stock brackets from another vehicle but was never able to get them to work with my setup, the Davis ones were so much simpler.
1963 Chevrolet C10 Stepside
1972 Pontiac GTO
1998 Dodge Viper GTS
1999 Jeep Cherokee XJ
2018 Chevy Camaro ZL1-1LE
It's never too early to beef up my obituary
brap999 is offline   Reply With Quote
