Old 05-12-2003, 08:11 AM   #1
gmc7286chevy
rear end gear ratio
I have an 86 chevy 1/2 ton 2wd with a 305, 350c trans and a 10 bolt rear end. I know somebody here knows what ratio this setup came with.
gmc7286chevy is offline   Reply With Quote
Old 05-12-2003, 08:12 AM   #2
gldevall
gldevall's Avatar
Check the tag on the inside of the glove box door. It should be listed there.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 05-12-2003, 10:51 PM   #3
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
There are lots of 10bolts with 2.73 / 3.07s. If you had a factory 6 cylinder or towing package you will more likely have better gears. Numerically higher like a 3.23 / 3.42 / 3.73.
Best way to find out is to pull the cover and count the ring and pinion. Im sure the differential could use an oil change anyway. You will get a chance to see the gears and how the ware looks on them. You will need 2.5 quarts of gear oil, a cover gasket, and a 3/8s drive ratchet to remove the fill plug on the passenger side by the driveshaft. I think the bolts are 1/2 or 9/16. Its really easy.
The RPO list should be in the glove compartment or in one of the fender wells (inner fender) sides.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 05-13-2003, 12:00 AM   #4
gmc7286chevy
Thank you,
Thank you very much!
