Old 05-13-2012, 11:27 AM   #1
Chvyman1975
Chvyman1975's Avatar
Torque converter in 350 trans
Hello does anyone know if they make different sizeTC's? I get mine fully seated and when I tighten it to the flywheel it slides forward enough to where I can fit my fingers behind it. I read that I shouldnt be able to do that. I have gone through another tranny because I didnt pay attention to this happening.
Chvyman1975 is offline   Reply With Quote
Old 05-13-2012, 12:34 PM   #2
PGSigns
PGSigns's Avatar
Re: Torque converter in 350 trans
The way I check converter fit is when it is installed I check the distance between the pads and the flex plate. Should be 1/8" or so, and if larger we shim it so it only comes ahead the 1/8".
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-13-2012, 01:02 PM   #3
Chvyman1975
Jimmy
Thanks for the response. What do you use to shim it?
Old 05-13-2012, 09:40 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Flat washers
