Old 05-13-2012, 08:17 PM   #1
meatballsub97
1971 Front End Alignment
I have a 71 K15 that has all new parts in front and a recent alignment. I am still having issues with drivability. The truck is very "darty" and hard to keep going in a straight line without a lot of constant correction. It also does not return to center at all when turning. I am looking to add some caster and or camber to it. Is this possible? I have seen ball joint sleeves but I don't know anything about these? I have read tons of posts about these trucks and alignments but I am still having trouble figuring out what to do. As I said ALL front end and steering parts are new, right down to the rag joint and steering box. Thanks for all the help as usual.
meatballsub97 is offline   Reply With Quote
Old 05-13-2012, 08:39 PM   #2
70cst
70cst's Avatar
Re: 1971 Front End Alignment
ist of all meatballsub97 ...
to the forum and from Ohio.
Here is a bump and I am sue you will soon get some feedback to your question.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 05-13-2012, 08:48 PM   #3
BMERDOC
BMERDOC's Avatar
Welcome to the board! Did you get a print out of your alignment results? Can you post them?
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 05-13-2012, 09:27 PM   #4
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I just went through this and one issue was the power steering gear was adjusted incorrectly. Mine was too tight and I was moving the wheel back and forth like mad....
Just a thought....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 05-13-2012, 10:35 PM   #5
Hubscrub
Cruzin
Hubscrub's Avatar
i would check the center link, very easy to install backward mine did the same thing and found out it was backward now drives great.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 05-15-2012, 04:08 PM   #6
meatballsub97
These are the numbers that the guy hand wrote on the slip. I question if he actually checked anything since I did not get a print out.
Camber .4 and .5
Caster 3.23 and 3.23
Toe .5 and .5
Old 05-15-2012, 04:09 PM   #7
meatballsub97
How do I cehck to see if the center link is in right? I am guessing the center link and drag link are the same thing? Sorry if that is a dumb question.
Old 05-15-2012, 06:46 PM   #8
BMERDOC
BMERDOC's Avatar
Caster looks fine. It would be great if camber was in the negative range. Toe however has me worried. I dont think thats a half inch and even if its in minutes or degrees thats still waay too much. The quickest way to tell if your centerlink is on backwards is to check for rub marks on the crossmember. A center link and drag link are indeed the same part. I'll see if I can dig up a good picture for you but I'm blinded by those toe readings if the are accurate.
Nick Carter
Old 05-15-2012, 10:22 PM   #9
Hubscrub
Cruzin
Hubscrub's Avatar
the center link install properly will be real close to the crossmember and also the inner tie rods will have the nuts on pointed foward. check this thread for picshttp://67-72chevytrucks.com/vboard/s...d.php?t=400205
Proverbs 3:5,6
Old 05-19-2012, 10:32 AM   #10
meatballsub97
Sorry about that, it should have been .05 each side with a total toe of .10.
Old 05-19-2012, 10:34 AM   #11
meatballsub97
Also, my truck is 4WD so the center link is different.
Old 05-19-2012, 06:45 PM   #12
Hubscrub
Cruzin
Hubscrub's Avatar
sorry I missed the (k) good luck finding a solution
Proverbs 3:5,6
Old 06-12-2012, 10:41 AM   #13
mark Ephland
Hay, Meatballsub. 97. Just read your post. Just finished my 68 3/4,disk brakes and power steering.Same symptoms as yours, No caster! The shop says not enough weight on the front end, may be needs a big block???? Never had a big block before. Going to another alignment shop this week. Maybe a bent spindle or upper control arm bent? If you have any luck let me know. markephland@gmail.com
mark Ephland is offline   Reply With Quote
