Old 05-13-2012, 11:38 PM   #1
LEEVON
LEEVON's Avatar
Tilt disassembly
I've searched all over the dang place, supposedly there is an FAQ but it must be hiding? I just need to disassemble the cancelling cam and turn signal switch to clean the guts and paint the column. I can't get the housing off...getting frustrated.
Anybody point me in the right direction?
Thanks!
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 05-14-2012, 12:07 AM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Tilt disassembly
Try this...
http://67-72chevytrucks.com/vboard/s...d.php?t=329008
and about a week ago...
http://67-72chevytrucks.com/vboard/s...d.php?t=523173
FirstOwner69 is offline   Reply With Quote
Old 05-14-2012, 01:23 AM   #3
LEEVON
LEEVON's Avatar
Thanks, I found those. What is not easily described is how to pull the housing off, a puller will bend the lip...I was able to tap it off from the backside with a screwdriver and hammer very gently and still managed to damage it a little. Not enough that it couldn't be bent, filed and sanded back though.
Old 05-14-2012, 06:46 AM   #4
jaros44sr
jaros44sr's Avatar
It shouldnt bend the lip, there isnt that much pressure holding the cover on. Just a slip fit, less damage then a screwdriver
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-14-2012, 02:10 PM   #5
LEEVON
LEEVON's Avatar
40 plus years of use and dirt had the collar on tight. There was no pulling it off. I was able to tap gently but firmly on the edge (not pry or bend) at the bottom of the collar while working around the column and slowly move it off. The spot that I nicked was an easy clean-up. Not the best way, but like I said the puller just starting bending the lip so I stopped before any damage took place. If there was a tool that would grab the majority of the lip it might have worked.
Old 05-14-2012, 03:32 PM   #6
jaros44sr
jaros44sr's Avatar
I guess, as you say, the puller should grab as much of the lip as possible. Mine wasnt that hard to pull off, so i suppose i was lucky....
Glad it worked out for you
SAFETY FIRST
AS usual, off topic
Jim
Old 05-14-2012, 04:49 PM   #7
LEEVON
LEEVON's Avatar
I'm just excited to have tilt! I looked for a true truck tilt (casually) for years and finally ran across one, it's been in my attic for about 9 months now. I don't slide in and out like I did 17 years ago
Old 05-14-2012, 09:57 PM   #8
jaros44sr
jaros44sr's Avatar
yeah, got your drift on your stature...
I made the mistake of taking it apart, sat on my workbench for two years, finally got the time to put it back together, and it sure was harder to reassemble
SAFETY FIRST
AS usual, off topic
Jim
