Old 05-14-2012, 03:38 AM   #1
Soap
Soap's Avatar
Steering Column Question
Hey everyone, my first chevy, but just the way I would have ordered it new. Anyway, I have an odd problem. It seems as if my steering shaft is grinding the column as I turn the wheel. It also disengages my turn signal too early if I start turning the wheel left or right. The steering shaft isn't parallel with the column either, it wants to pull upward. Is it suppose to be this way?? Missing a bearing somewhere perhaps?
1968 Chevy C-10 305 NP 435 4-speed granny
1968 Pontiac Lemans 350 Pontiac 350 turbo
1977 IH Scout II Travelall 4x4 345 International auto
Soap is offline   Reply With Quote
Old 05-14-2012, 05:34 AM   #2
JimKshortstep4x4
Re: Steering Column Question
Welcome to the 67-72 Chevy Truck board from West Michigan!
Look at the column close to the outside firewall to see if there is a spring in place on the shaft itself. Here is a picture of the setup.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 05-14-2012, 05:46 PM   #3
Soap
Soap's Avatar
heya from KS! nothing looks out of place, but it's a little different from yours. is the spring not seated correctly? there's an open spot on the column where the nuetral safety switch is usually mounted so i was thinking the column might not be original seeing that it's a 4 speed. would also explain the funny choice of interior color and missing glovebox sticker..
