Old 05-12-2003, 12:49 PM   #1
TIMSPEED
TIMSPEED's Avatar
5/7 drop question: What size tire could I run?
Could I run a 255/50 17 with a 5/7 drop? Right now, I'm running a 255/55 17 with a 3/5 and not having any rubbing issues at all. (Well, ok...ONE, but I don't think it's RUBBING, I think something else is hitting) But my rim is 9½" wide with a 5½" backspacing. Also, would I need to change my shocks? I'm running DT's both front and back. I think they told me the front's are basically stock replacement size, but the backs are for a flip kit. (can't recall the exact #'s right off hand) I know for a fact I'll have to change my headers (to those G body ones for $209) But other than that, and C-notching my frame...I think 5/7 will have to be put on soon
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 05-12-2003, 08:39 PM   #2
1FaastC10
1FaastC10's Avatar
255 60 15s
1FaastC10 is offline   Reply With Quote
Old 05-12-2003, 11:32 PM   #3
low 84
low 84's Avatar
i'm on 56k now so i'm being very lazy and not looking up the diameter of a 255/50/17. but you need a tire thats close to 27 inches of diameter.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 05-12-2003, 11:58 PM   #4
TIMSPEED
TIMSPEED's Avatar
255/50 17 is exactly 27"
See Them Here
Old 05-13-2003, 12:44 AM   #5
low 84
low 84's Avatar
it should work fine then, as long as your backspace on your wheels is correct
'05 1500 Crew Cab
RIP
Old 05-13-2003, 01:20 AM   #6
slammedLT1
slammedLT1's Avatar
i got 235/60 on 8 inch in the front and 275/60 on 10 inch in the back, mines 5/7 look at my pics if you can see on my site
as for the shocks you cant go wrong with summit. $25 a piece, i bought a set of four just front and rear drop shocks. you will need front drop shocks aswell to get the proper valving.
good luck
DIGGER
1984 GMC Sierra 1500 LQ4 T56 12B Chopped 2 1/4, Dropped 6/7, Shaved, Yenko Stripes
2004.5 CCSB GMC 2500HD DMAX LLY, 6" Liftmaster, 6 Fox Resi 2.0 325/50/22" Kumho A/T on KMW's LBZ MP, 5"Ex, Bullydog GT
1996 ECSB GMC Sierra 1500 350/4L60E, FL Headers, 2450 Stall, 6" Pro Comp,3" BL, Shock Hoops, , TrXus STS 38's
slammedLT1 is offline   Reply With Quote
Old 05-13-2003, 02:14 AM   #7
TIMSPEED
TIMSPEED's Avatar
Ryan,
Would the shocks I'm currently running work witha 5/7, or would I have to change to a lower shock?
See Them Here
Old 05-13-2003, 10:41 AM   #8
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Originally posted by slammedLT1
....mines 5/7 look at my pics if you can see on my site
Where/what is your site URL?
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 05-13-2003, 10:44 AM   #9
slammedLT1
slammedLT1's Avatar
you may be able to use them but also think that with the 5 inch drop in the front, you'll be cutting the bumpstops down and the shock isn't designed to work at that length, you will see alot of shock absorber fade with a stock shock absorber, if your on a tight budget you could probably use the stock shock, just mount it with out the spring in place and push the lower control arm up and see if your shock will travel well enough and won't bottom out... thats my suggestion, i mean you are going with spindles and springs right?
but other than that it may be possible, but keep in mind that your normal shock travel will now be 3 inches less than stock and the normal working length of the shock is now that much more compressed at all times ( assuming 3 inch coil drop)
oh yeah with the 5/7... get a skidplate!
at night you may notice a few sparks...
DIGGER
Old 05-13-2003, 10:47 AM   #10
slammedLT1
slammedLT1's Avatar
http://www.cardomain.com/id/quikslvr
theres my site (car domain)
DIGGER
Old 05-13-2003, 12:25 PM   #11
TIMSPEED
TIMSPEED's Avatar
(assuming 3 inch coil drop)
Actually, it's only a 2" coil drop. Also, it's not the STOCK shock, it's a Doestch Tech, it's just stock SIZE (so they said) Here's my shock part #'s:
4052G(Front)
4095G(Rear)
I guess for a 4" front drop, I could run the 4052's, but I think that's assuming 2" spring/2" spindle...so I may be ok, cuz I WILL have a 2" spring
See Them Here
