Old 05-14-2012, 10:44 AM   #1
melks
melks's Avatar
bench seat
is there any way to modify a stock bench seat (in my 1984 for this example) so that it can bend/pivot forward...From the factory they seem to be fixed in an upright position...I would like to use the little bit of space behind the seat for my back pack and other things but the only way i can get behind the seat is to remove the 4 bench seat bolts. Any help or advice is greatly appreciated.
1984 Chevrolet C10
melks is offline   Reply With Quote
Old 05-14-2012, 10:50 AM   #2
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: bench seat
The bench seat in a regular cab is supposed to fold forward. The front bench seats in a crew cab or suburban did not fold forward. Perhaps yours was swapped sometime in its life? The 84 should fold though, for sure. Some of the 70's trucks they did not fold up.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 05-14-2012, 01:04 PM   #3
melks
melks's Avatar
Re: bench seat
hmm...yea i guess mine must have been swapped throughout the years...any ideas or input on how to modify a fixed position bench seat so that it can fold? and thanks RandyP.
1984 Chevrolet C10
Old 05-14-2012, 03:35 PM   #4
dead civic
dead civic's Avatar
Re: bench seat
youd be better off it you buy a bench that folds.
00 EBP civic SI [not stock for sure]
03' Jet black CTS {slammed on ksports}
79 C10 [real project]
POW MIA. .SMOKE TIRES NOT DRUGS.
dead civic is offline   Reply With Quote
Old 05-14-2012, 05:01 PM   #5
Dsquared
Re: bench seat
if you take the piece of upholstery that comes off of the backrest and hooks to the bottom at the seat belt loose from the seat, there are two bolts, just take out the rear bolt then it will fold. you have to do both sides.
Dsquared is offline   Reply With Quote
Old 05-15-2012, 07:55 PM   #6
melks
melks's Avatar
Re: bench seat
im going to have a look tonight and see if i can pull this off...
1984 Chevrolet C10
