05-14-2012, 04:02 PM | #1 |
Help with brake line routing
Been reading on here which line goes where from the proportioning valve and I"m alittle confused where mine run to,large opening on rear of prop valve to rear brakes and small line at bottom to front brakes?My prop valve looks a little different than other pics.(this is a 72 chev 1/2t, disc on frt and drum at back),I"m thinking i have a later model valve?any ideas,thanks,i hope the picture comes up as i"m new to this site
05-14-2012, 04:47 PM | #2 |
Re: Help with brake line routing
Yours looks just like the one on my 71.
Posted via Mobile Device |
05-14-2012, 04:54 PM | #3 |
member #16
Your lines look like 3/4 ton lines. The 1/2 ton lines go front to front and rear to rear. 3/4 are opposite like yours.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 05-14-2012 at 05:05 PM. |
05-14-2012, 05:04 PM | #4 |
I guess i need a different prop valve for 1/2t or could i still use this set up ? thanks for reply
05-14-2012, 05:08 PM | #5 |
member #16
I added a 1/2 ton pic. I dont know why they were plumbed different, or why yours wont work as is.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
05-14-2012, 05:20 PM | #6 |
Is your truck a 4x4?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
05-14-2012, 05:33 PM | #7 |
No its a 2wd
