05-12-2003, 01:35 PM | #1 |
Keep On Truckin'
Gas tank outside frame rail
Has anyone tried to mount a gas tank on the outside of the frame rails on a 67-72 short wide bed like was done on the 1973 and later trucks before it was moved inside the frame rails? If so what tank was used?
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
05-12-2003, 01:56 PM | #2 |
Livin' it up.
i had original tanks outside the rails in my 69 when i got it.. they were rusty on the insides and junk so i cut them out. i'm unsure of their dimensions but know some trucks had em. sorry i cant be more helpful
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. |
05-12-2003, 06:30 PM | #3 |
assuming the necessry room is available undeneath the cab/bed, all you need is the tank and the straps from the 73-87 model. of course, you will have to drill the necessary holes in the frame rails to set it up. then, of course, you will need to weld in a fuel door, etc.....
good luck!! |
05-12-2003, 06:35 PM | #4 |
Robert Olson Transport
why put in outside the frame tanks us 73-97 guys have been killing ourselves to put em int he rear where its safe!!!
05-12-2003, 11:33 PM | #5 |
its all about the +6 inches
Even if date line (or was it 20/20?) did add a spark in there infamouse report... it is still a bad location for a tank.
