Old 05-12-2003, 01:54 PM   #1
gbkwork
Transmission (TH350) Problem
This site has been a huge help in the past so when my transmission intermittently stopped engaging I thought I would give all of you a shot at it.
Here's the problem:
When I shift from park into any drive gear (including reverse) no power gets to the wheels...the engine just revs. I have checked the linkage and it appears to be operating OK outside of the case.
I plan on upgrading the tranny at some point in the future for towing purposes and the future installation of a built engine, but I did not intend on doing this right now. If anyone knows of a quick fix I would appreciate it.
'72 Custom LWB
383 ci, Lunati 213 / 219 cam (60101L), 2.02/1.6 heads, Crane roller rockers, HPC coated ramhorns, FIRST TPI, '90 Corvette ECM, , Built 700R4, 3.73 Eaton Posi 12-bolt, Magnaflow dual exhaust, PW, Keyless DL, ECE Hidden Hitch, New chrome all around, 17" Torq Thrust II's, 255/50 & 275/50 Nittos, ART airbags, Rick's custom tank w/ custom in-bed filler, '02 Silverado seats, Rod Doors headliner / A-pillar covers and door panels.
gbkwork is offline   Reply With Quote
Old 05-12-2003, 02:13 PM   #2
COBALT
COBALT's Avatar
Check the fluid. This always happens when the valve body isn't getting enough fluid pressure to change the fluid direction in the valve body to apply the pin for reverse, or engage the clutch packs for 1.
You say it happens every once in a while? How long do you let it sit in gear when this happens? Don't be imatient. Next time it happens let it sit there and time it with a stop watch. See if the length of time it takes to finally pop into gear gets longer and longer. If it does your clutch plates and apply band are shot.
What's the fluid look like?
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 05-12-2003, 02:19 PM   #3
jku72
If its just slow in engaging, but does eventually, it sure is a sign of low pressure. What causes low pressure? Dirty filters, low fluid levels, or leaks. It could be the pump is going away, but my money is on fluid level first, dirty filter second.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
