Old 05-12-2003, 02:16 PM   #1
da-burb
"Ochre Ogre"
da-burb's Avatar
4x4 raised steering arm removal
Is there a trick to removing the stock steering arm? I left my truck with the mechanic to finish the 4" lift spring install. The last thing to install is the raised arm. The old one just doesn't come off. Any helpfull hints????
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 05-12-2003, 03:19 PM   #2
Blazer1970
Blazer1970's Avatar
Hit it from the side, hard, with a big hammer. You want to hit from the side right next to the studs, one at a time. This will deform the holes in the arm (momentarily) so that the cone washers that are in there will break loose. It is the same idea that is used to get tie rod ends and drag link ends to separate.
Blazer1970 is offline   Reply With Quote
Old 05-12-2003, 08:35 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Like Tim said hit it from the sides (I used the back of a 3.5lb axe). Trying to strike from the bottom or using a jack and the vehicle weight to remove will only make them tighter.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 05-12-2003, 10:57 PM   #4
Mike C
Mike C's Avatar
Sometimes they are a BEE-OTCH to get off. To say the least. Soak them in penetrating oil and use an air chisel at the top. This worked on one of mine. Next thing is to put some heat on the wedges. I FINALLY got mine out after a couple of sessions with hammers, chisels, oil and heat. FYI, I had to go get new tapered shims.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-12-2003, 11:08 PM   #5
da-burb
"Ochre Ogre"
da-burb's Avatar
Oh this sounds like so much fun! I am starting to remember why I stayed away from 4x4's for the first 24 years of vehicle ownership.
Old 05-13-2003, 07:35 AM   #6
TX_Mudder
Not everything is as big a PITA as that steering arm. The 1-ton front axles are easier to work on. The steering arm is held on by 4 1/2" nuts (on studs.) Easy. Also, no ball joints - very easy to rebuild and not special tools.
Once you get the steering arm off you'll feel better
-- Mike
TX_Mudder is offline   Reply With Quote
Old 05-13-2003, 12:15 PM   #7
694X4
694X4's Avatar
Yep beat the sh!t out of it with a 3 lb mini sledge and some time after your arm wears out it will come off. I was helping a friend do his one time and he offered a free steak dinner to the person that got it off. I beat on that thing till i couldn't feel my arms any more then his dad hit it three time and it fell off on the floor.
69 3/4 ton 4x4 gmc with 6" sky jacker soft ride. 350 / th350 / 205
work in progress
694X4 is offline   Reply With Quote
Old 05-13-2003, 12:56 PM   #8
Mudder
Mudder's Avatar
Ah come on guys they all arent that bad! LOL You have to hold your mouth in the right position and say the right words.
694x4 you should have wacked it 3 more times! LOL
Old 05-13-2003, 04:56 PM   #9
694X4
694X4's Avatar
Trust me mudder i was saying some words maybe not the right ones but words all the same.
work in progress
Old 05-14-2003, 01:34 PM   #10
da-burb
"Ochre Ogre"
da-burb's Avatar
It's off!!! And what a diff it made in the steering. Now I have the complete Tuff Country 4" lift kit on the truck at all 4 corners.
Old 05-15-2003, 10:47 PM   #11
kwmech
arm
For future removal for any one. I do these all day long and for the stubborn ones after soaking and side hitting try this also--- put the nuts on half way and with an air chisel with blunt end [such as you would use to blow out rivets thru the frame] hit the top of the stud also. The nut prevents damage to the threads-most of the time.
Old 05-18-2003, 12:43 AM   #12
Ryan Flowers
No Brakes Club
Ryan Flowers's Avatar
Hit it from the side! That's how I got mine off when doing my lift. Just tap it on the sides and watch for the cone washers to start lifting up. Then you can just pull them up and then the whole thing will slide off.
Hope this helped?
Later,
Ryan Flowers
85 GMC Suburban 4x4 379
90 GMC Suburban 4x4 383
01 Chevy Suburban 2x4 350
Click here to email me
Click here to visit my web site
Ryan Flowers is offline   Reply With Quote
Old 05-31-2003, 07:06 PM   #13
bodazpa
bodazpa's Avatar
take the wheel and breake assembley off, heat it till it glows, then hit the snot out of it with a heavy hammer.The tech from tuff country told me to hit it wuth a soft hammer, I told him that the 5lb maul that I used must have been to heavy....
71 chevy 4x4 ,np205 transfer case, 3 speed tranny, sjs 283, 4in suspension lift, and 71 hugger orange paint,33x12.5 parnelli jones on 15x10 m/t classicII, cowl hood,new bed painted, linex liner. Truck has been completed since 2005....
2003 Chevy Avalanche Z71, on 6in super lift w/ 35in tires
RNG4x4 aka the "Redneck Roller"
words to live by "If it fits, it fits"
"friends help you move, real friends help you move bodies..."
Sponsored by "Kick Ass Kustom"
bodazpa is offline   Reply With Quote
