Old 05-14-2012, 11:32 PM   #1
TurnNBurn
Brake Drums Stuck on
I'm trying to replace a wheel cylinder on my 89 R 1 ton. I cant get the brake drum to save my butt. I backed pads off, used lots of oil, heat ,hammers. What am I missing???
TurnNBurn is offline   Reply With Quote
Old 05-15-2012, 07:44 AM   #2
tobiahr
tobiahr's Avatar
Re: Brake Drums Stuck on
is it moving at all? if it is the pads are stuck in the grove and you can unstick them with a small screwdriver from the back of the drum. just take your time. if the drum spins but is not moving otherwise its rusted to the axle flange. wd40 to the hub and wack it (not to hard) with a hammer to try and break up the rust
tobiahr is offline   Reply With Quote
Old 05-15-2012, 09:59 PM   #3
TurnNBurn
I have tried all the above, i guess i just kep banging it.
Old 05-16-2012, 03:10 AM   #4
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Go to the backside of the backing plate and remove the bolts for the wheel cylinder and the brake line as well. then take a grinder to the heads of all the brake shoe retainer pins (may have to use a dremel tool) and grind away carefully until your thru all of them. Get (rent) a brake drum puller and put it to use.
If that don't work......use a hot wrench and torch that sucker off.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 05-16-2012, 11:41 AM   #5
Ski-me
Ski-me's Avatar
Is the rear a semi-float or full float? If semi, could you pop the diff cover off and remove the c-clips and then pull the axle shafts out?? I'll be trying the same thing on the SF I just bought where the drums won't come off either.
Ski-me is offline   Reply With Quote
Old 05-16-2012, 03:36 PM   #6
Cherub
Cherub's Avatar
I know it might sound dumb but is the emergency brake off.........dont ask how i know
Cherub is offline   Reply With Quote
Old 05-16-2012, 10:38 PM   #7
v30crewcab
v30crewcab's Avatar
you sure the drum slides off? I got a feeling you gots to pull the axle shaft and bearings and take off the whole hub assembly. thats how my 88 works.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
