![]() ![]() ![]() ![]() ![]() Last part is a chunk of speedbump I guess you can say I learned fast lol Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Re: Feel like I'm finally cool enough -6-8 drop
Nice drop. You may have mentioned before but what is your tire size front and back? Im still trying to figure out just how low I want mine. Thanks
That stance looks good.
Slots go on anything!
Looks good.
1974 Jimmy- 5.3/4L80e/NP241 |
Looks killer!! And you will see every road in your town in a new light now. Lol
John 82 Chevy Silverado 350ci/TH350 ![]() |
so true i dropped my truck and drive it a lil better then i use to
Edited by staff |
nice truck
Looks great!
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
#10 | |
I really need some 18s to help clear the a arm though couse the inside lip of the wheels grind lock to lock Posted via Mobile Device
lookin good dude. maybe i'll see it in person next weekend
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
So whats the specs on the drop?
#13 |
Yah hopefully I can get all the bugs fixed before the swap meet. The rear is loose as sin since djm doesn't know how to make a flip kit anymore I guess. The flip bracket is to short and won't sit all the way under the leaf pad on top. So every time it goes into gear it slides my pinion angle up or down a good 5*
#14 |
3" springs up front djm 3" drop spindles (soon to be changed to cpp modular for big brakes). Lca moved forward an inch energy susp bushings. Qa1 adjustable ball joints. A useless djm flip kit with shock extenders and a 1-2 lowering shackle in back.
#15 |
oh jeez, how are you going to fix that? could you weld some shims on top of the flip bracket?
#16 | |
#17 |
i now know what it feels like to be low (in the back). i just haued a bunch of dirt fro my moms garden. the axle was hitting the frame the whole way home
#18 |
Only thing I haul is a$$ anymore haha
#19 |
Looks sweet!
#20 |
stance looks great man!
1984 Chevrolet C10 |
#21 |
Your truck was already cool enough IMO. Nice improvement with the drop.
Joe __________________________________________ 1975 C10 "Questions are a sign of intelligence indicating a desire to eliminate ignorance" |
#22 |
insidious...take some more pics! daylight ones! i love the look of it!
1979 GMC Sierra Classic Freshly lowered 5 inches ![]() ![]() |
#23 |
Its quite nice down here isnt it :P
Matt |
#24 |
![]() Posted via Mobile Device
#25 |
Dear god this thing grips the corners! And it's not even aligned! The caster mod and one ton sway bar do wonders. Not to mention qa1 ball joints and urethane bushings help
For those that may wonder what the caster mod is take the shafts on your lca (lower control arm) and drill them to move the lca forward 3/4 to 1" inch I did with some layout die and an 11/16 jobber bit. This should net you 7*+ neg caster which is great for anti dive and turn in and camber gain in a corner. Some trimming of the crossmember and/or bushing sleeve will be required also get rid of your stock upper ball joints. The only move in one direction! In and out and Hardly back and forth so these can bind easily. Some pics of the control arm moved forward ![]() ![]() ![]() Posted via Mobile Device
