Exhaust Fumes
I'm trying to find the source and may you guys can help me out. I put new headers, exhaust, mufflers... but for some reason I get exhaust fumes inside the cab. Is there something I should look for under the dash?? I dont see any holes in the firewall.
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Exhaust Fumes
perhaps there is a rust hole in the bottom of the cab the door seals are not tight? is the exhaust properly bolted on like are the headers set on a gasket and are the bolts tight enough?
also if all else fails is the exhaust dumping in a place where it will blow back into the cab?
Re: Exhaust Fumes
No rust...Exhaust is new and sealed. Headers are properly bolted and exhaust runs all the back to rear bumber. Doors are sealed too. It seams to come thru the vents.
78K & 79C Jimmys
Re: Exhaust Fumes
on my 78, valve cover blowby
from the steering wheel(actually turn signal lever hole) and how is your cowel seal(hood to firewall)
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Re: Exhaust Fumes
Just for kicks try putting the tailgate down and go for a drive. The factory pipes were out the side behind the rear tires.
Re: Exhaust Fumes
There at plastic plugs under the seat. Sometimes thes disapear.
You clearly have a leak somewhere. Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Re: Exhaust Fumes
Did you re torque the headers a week later?I know the exhaust is new but is it clamped or welded together?
Re: Exhaust Fumes
Think I found it... where the headers connect to the exhaust it had a gasket instead of the donut. Put in donuts on both sides nothing yet...
Thanks |
