Old 05-12-2003, 03:30 PM   #1
BigRed
Looking at buying a '67
I am looking at buying a '67 lwb and am curious about the differences between the 67 - 72s. I don't expect anyone to list them, but what are some good websites to reference.
Also, what are some problem areas and other things to to look at on this truck when I go out and see it?
I'm a 73-87 guy, so that's why I'm kinda brain dead on these year models. Although I've always wanted one and am excited about the possibility of one sitting in my driveway (or garage)!
Thanks,
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 05-12-2003, 04:11 PM   #2
Blue Beard
Blue Beard's Avatar
71-72 are easier to swith over to disc brake if they don't have them.
They are more sought after trucks. I believe they have more and better options.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 05-12-2003, 04:25 PM   #3
Blue68
Blue68's Avatar
Are you looking for visual differences or mechanical? GMC or Chevy?
Personally, the 67-68 has the better styling, due to the front clip, which is really the main style difference. mechanicals are pretty much swappable among all years, including up to '87 on some items (with slight modifications here and there). Disc brakes appear in '71. Engine options in '67 were the 283, 327 and I'm sure an inline 6. '67 also had the big and small rear windows both.
If you are looking for a specific area post the questions and I'm sure you'll get a better response.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 05-12-2003, 05:09 PM   #4
Jwill41
Jwill41's Avatar
No side markers in 67
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 05-12-2003, 11:46 PM   #5
BigRed
Thanks for the responses! I was looking for just general differences (mechanical and body wise). It's a Chevy and not a GMC. It does have factory air and is a LWB.
I have a '75 that will somewhat act as a donor to this truck if I get it. For instance, the '67 has a 327 in it that is most likely blown so I'll put my 350 in there and probably my newly rebuilt TH350. It has no carb and alternator which will both come off of my truck and go in this one. Then, I will part out my '75. I might even swap front ends and will at least have 2 discs! We'll see.
Scott Shelbourne
Old 05-13-2003, 12:29 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Big Red...that sounds like a plan to me...a 75 would be a good donor truck.
Being that you are in Texas, the 67 should be fairly clean. Check the rockers and the cab corners for rot...or worse yet, rot repair. While under the cab, look at the floor boards and cab mounts. Any other rust should be easy to spot, and in your location...it'd be a good reason to walk. These things are a dime a dozen in your area...pick up any thrifty nickle, you'll see at least 5 in any given week.
Other than that, there is no real "wear items" to look at that you wouldn't look at on any other 37 year old vehicle.
Well....if it has the coils in the back (if you are lucky than it does) then look at the rear trailing arms real closely...some ppl have been finding them rusted and falling apart.
Any chance of getting pics?
Old 05-13-2003, 07:54 AM   #7
Huck
Huck's Avatar
Will add a couple of spots to look at from Andy's post. Check the inner cab roof above the windshield as if rust is showing there, it's more trouble then it's worth to fix. Another problem spot is the firewall where leaves go thru the cowl and collect in the inner cab vent boxes. This will typically show at the firewall, from under the hood look at the firewall above the heater motor and at the same area on the other side. If rust thru there, it could go well beyond and below. If no rust damage, your good to go.
In general terms, these trucks are as valuable as their body is. Drivetrains are interchangeable and cheep. Frames are cheep. Cabs, beds, front clips, trim, get pricy and very time consuming to repair. Good luck and keep us posted on your progress. Huck
Huck is offline   Reply With Quote
Old 05-13-2003, 11:01 AM   #8
BigRed
Thanks Huck! Here's some pictures.
http://www.shelbournes.net/trucksite...er/67chevy.htm
I know it's rough, but she may still have life. The guy is giving me two fenders and a door with it that are in good shape. I told him $500 was high that I would give him $200 and he's thinking it over.
Scott Shelbourne
Old 05-13-2003, 11:42 AM   #9
Hutch
Hutch's Avatar
Hey it is a local truck.
The dealer emblem on the tailgate says Vandergriff Chevrolet which is in Arlington.
I think I saw this truck before like down in Grandbury TX.
Lots a good parts there.
Have fun
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 05-13-2003, 09:23 PM   #10
Longhorn Man
If this is the extent of the rust, then go for it. But this is a good chore to repair in its self.
Huck, thanks for adding to my post...I have no idea why I didn't ention that since my GMC suffers from both fire wall rot and natures sun roof over the windshield.
Old 05-14-2003, 09:35 AM   #11
Blue68
Blue68's Avatar
It would make a pretty good parts truck since it looks like most of the sheet metal is in decent shape, even at $500. There's some decent trim pieces left. It has what appears to be a good tailgate. If you wait and spend an extra grand, as in $1500, you can get into one that is in better shape and that someone has probably been driving.
Old 05-14-2003, 02:22 PM   #12
griesel72
griesel72's Avatar
I like the 200 idea. When you get a truck for 200, you can afford to put some money into it. but i guess that these trucks are a dime a dozen here in Kansas.
david
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 05-14-2003, 02:58 PM   #13
Davy
Davy's Avatar
Dime a dozen??? I wish that was the case up here. This is about all I see in MN.
1970 Blazer CST
Looking for NOS items for my CST restoration.
Davy is offline   Reply With Quote
Old 05-14-2003, 03:01 PM   #14
Davy
Davy's Avatar
Hey Bigred, I forgot to mention...if I found a truck like that here for $200, it would already be in my garage stripped down to the frame waiting to be restored.
Good luck.
Davy
1970 Blazer CST
Old 05-14-2003, 11:16 PM   #15
Longhorn Man
Davy, the body on that still looks better than what I'm driving.
Old 05-14-2003, 11:32 PM   #16
68 Suburban
68 Suburban's Avatar
Originally posted by Blue Beard
71-72
Really? Where are the stats on that one
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 05-14-2003, 11:34 PM   #17
BigRed
Well guys, I passed on it as did one of my friends who owns a '67. It was very rough. Don't think I've ever seen that many wasp and mud dobber nests in such a small area! I guess it would be good for someone, but not me right now. Oh well. Thanks guys for all your help and advice!!! I guess back to the 73-87 board for me.
Scott Shelbourne
Old 05-17-2003, 06:41 PM   #18
Hutch
Hutch's Avatar
If you are going to pass on this one.
Send me a pm with the location or phone number.
It may have some parts I need and I might cosider splitting the cost with someone who needs other items.
Have fun
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
