Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-15-2012, 07:50 PM   #1
hotrod 80
mini truck racer
hotrod 80's Avatar
Oil leak at slip collar
I have an oil leak at the slip collar on my MSD distributor . I can see it coming from the split were the allen set screw is . The depth is correct and i have replaced the gasket . Anybody ever run into this or have any suggestions ? This is a small block chevy .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 05-15-2012, 08:29 PM   #2
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Oil leak at slip collar
Google is my friend . Looks like a common problem and silicone needs to be added .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-15-2012, 09:59 PM   #3
PGSigns
PGSigns's Avatar
Yup with those the solution is just a little black rtv the first time in the hole. Seems to fill the small gap for a good while.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-16-2012, 02:00 PM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
Tell me if this sounds correct on the slip collar setting .
Set collar @ .043 gap from intake minus half the gasket which was .062 =.031 depth =.012 . Spec is .010-.030 .
.043 gap
-.031 ( approx for gasket crush )
.012 depth
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-16-2012, 06:53 PM   #5
Marv D
Registered Truck Offender
Marv D's Avatar
What I do,, is set the distributor in and seat the collar against the intake with no gasket. Then with the gasket added you have around 0.010-0.020. Has worked for me in everything I've used them in.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 05-16-2012, 07:40 PM   #6
hotrod 80
mini truck racer
hotrod 80's Avatar
Thanks , again sorry instructions . I found that formula under Chevelle forums . Just wanting to be sure . Tearing up the cam gear would suck .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-07-2012, 10:51 AM   #7
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
AS always Marv is on top of it.. And a little dab will do ya on the RTV..
GMR-PERFORMANCE is offline   Reply With Quote
Old 06-07-2012, 11:08 PM   #8
hotrod 80
mini truck racer
hotrod 80's Avatar
That solved it .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-18-2012, 09:57 AM   #9
GMR-PERFORMANCE
The slip collars are nice but I have had those leak at the collar and shaft.. RTV needed there as well LOL.
