Old 05-15-2012, 09:26 PM   #1
bigwheel15
bigwheel15's Avatar
TH350c worth it?
Well ive always thought I had a standard th350 but after getting under there today to change my pan gasket and filter I found out I have a th350c. The previous owner clipped the wire after about a foot and wrapped the wire around the frame. Now what im wondering is is it worth gathering all the parts to get it to lock up? What are the benefits? I know you can throw it on a toggle switch but I dont really like the idea and dont wanna add any switches to my dash.
BTW I dont mostly city driving with occasional highway driving.
bigwheel15 is offline   Reply With Quote
Old 05-16-2012, 04:04 PM   #2
bigwheel15
bigwheel15's Avatar
Re: TH350c worth it?
Anyone?
Old 05-16-2012, 04:26 PM   #3
monte0185
monte0185's Avatar
i wired one up thru my cruis control switch one time that way when i hit the brake it unlocked but there really wasnt much of a benefit. Just did it to see what it would do.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 05-16-2012, 04:52 PM   #4
Firebirdjones
It will only drop the rpm about 2-300. Might notice a very small change in mpg but with a tight stock converter to begin with, it's not all that much.
Firebirdjones is offline   Reply With Quote
Old 05-16-2012, 10:07 PM   #5
rwhit57
rwhit57's Avatar
I like mine. Like said the rpm drops about 200 when it locks up. All the stuff is probably still there on yours, if not all you need is vac switch on the firewall. Someone here at one time showed the wiring dia. They seem to be tough trans. I have 130k on mine, still shifts good and the fluid is clean and red.
"Whoever said money can't buy happiness has obviously never seen a speed shop!
rwhit57 is offline   Reply With Quote
Old 05-16-2012, 10:28 PM   #6
INSIDIOUS '86
INSIDIOUS '86's Avatar
Will keep your trans from overheating and blowing up. Otherwise it's in constant slip and creates more heat than a normal th350
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 05-16-2012, 11:47 PM   #7
bigwheel15
bigwheel15's Avatar
All the stuff for it is long gone but I could go junkyard hunting and scrounge up the parts necessary. I did some searching and found the steps necessary to get it functioning, is there a way to test to see if it still locks up correctly?
Old 05-17-2012, 01:33 AM   #8
rwhit57
rwhit57's Avatar
If you put 12v to the solenoid on the trans. it should work. I would try it through a toggle and see. Correctly it's wired through the brake switch and the vacuum solenoid on the firewall.
