05-15-2012, 09:34 PM | #1 |
Registered Cruiser
Steam Line help...
I'm trying to figure out the best place to drill and tap for the steam line fitting in the new water pump for my 5.3. I've seen most tap into the "bubble" near the upper neck (mine has no bubble), and also have seen some tap into the water neck on the thermostat housing... What do you guys suggest with the Pump pictured below?
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
05-15-2012, 09:53 PM | #2 |
Re: Steam Line help...
Route it to the radiator tank like GM intended, Drilling a hole in that new water pump will void the warranty.
Any good radiator shop can solder a 3/8" brass hose barb in the tank, Im guessing your using the original Brass/Copper radiator? |
05-15-2012, 09:56 PM | #3 |
Registered Cruiser
I will be using a new alum rad., elec fans. Should I just have them add the fitting when ordering then??
05-15-2012, 10:34 PM | #4 |
I got a Griffin radiator this week for my 65. It is set up for LS engines with the 1-1/4 inlet moved to the passenger side and 1-1/2 outlet. It came with a 1/8" pipe bushing welded into the top tank for the steam line. The LS1 book put out by GM says to route the steam line to the highest point in the coolant system, top of the radiator tank.
Good luck, TR PS My Champion radiator puked on me.
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
05-15-2012, 11:14 PM | #5 | |
Yes, you can order a aluminum radiator with provisions. |
05-16-2012, 12:20 AM | #6 |
Registered Cruiser
Thanks for the reply's, big help guys!
05-18-2012, 10:12 PM | #7 |
I drilled mine on the back of the water pump outlet....
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
05-24-2012, 03:05 AM | #8 |
Are steam lines only needed on fuel injected engines or on a carbed motor too?
05-24-2012, 08:31 AM | #9 |
A guy with a truck
Induction is of no consequence. The LS cooling system needs to be able to purge steam pockets. Since there is no coolant in the intake, the highest point of the system is the front of the cylinder heads; steam lines give it place to evacuate.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
05-24-2012, 09:26 AM | #10 |
I took my aluminum radiator to the shop and had them add a 1/4" nipple to the top tank.
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
05-24-2012, 11:45 AM | #11 |
I drilled and tapped the top of my pump, about 1" to the right of the outlet. See pic in post #18 http://www.67-72chevytrucks.com/vboa...d.php?t=520516
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292 1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987 Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker |
