05-15-2012, 09:43 PM | #1 |
Dash pad repair?
I have a better than what I got now dash sitting in my garage, question is could I use bondo to repair the cracks in it? Its got bout 3 or 4 cracks in it. Any help is appreciated
Posted via Mobile Device |
05-15-2012, 09:47 PM | #2 |
Getting Old; Going Broke
Re: Dash pad repair?
In the little box up above, type "dash pad repair" and check the box that says 67-72chevytrucks.com. You'll find many many many threads about it.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
05-15-2012, 09:52 PM | #3 |
Thanks bud, I honestly didn't have a clue as to how to search the entire site . I'm a newbie.
05-15-2012, 10:07 PM | #4 |
Catchy title goes here..
And you will find this is one of the friendliest places around. Using the violin smilie makes you look as if you were annoyed at the help. Im sure you meant it at yourself; but just saying how it looks.
One thing I will say is the site owner HATES the reply of use search. Not that it's wrong, but it makes folks feel like they can't ask a question. Feel free to ask all you want, and don't take folks replies the wrong way. You will find there is a good bunch of people around here who are willing to take the time to help you find the answer you need. |
05-15-2012, 10:17 PM | #5 |
I had found this article and it was pretty helpful to me. Hope it works for you. Thats IF you decide to cap it..anyways....
http://www.moparmusclemagazine.com/h...ild/index.html |
05-16-2012, 10:10 AM | #6 |
Can someone post a link to thread that has any good steps? I'm having a hard time searching. All help is truely appreciated
05-16-2012, 12:35 PM | #7 |
Hey John welcome you will find that some people on this site will help you , good luck with your dash.
05-16-2012, 12:41 PM | #8 |
05-16-2012, 01:32 PM | #9 |
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
05-16-2012, 03:39 PM | #10 |
05-16-2012, 07:47 PM | #11 |
Also has some decent info and mentions dash caps which are a cheaper solution: http://67-72chevytrucks.com/vboard/s...d.php?t=503375
05-17-2012, 01:52 PM | #12 |
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
05-17-2012, 04:43 PM | #13 |
John - Not sure if this was already posted, but you may want to give this thread a look. IMO, dash pads are cheap and plentiful enough that it's more trouble than it's worth trying to repair them. But that's just my take on it.
http://67-72chevytrucks.com/vboard/s...d.php?t=512405 |
05-18-2012, 11:42 PM | #14 |
I redone mine but I removed all the original covering and fiberglased over the steel frame. Done it all and painted it to match the truck for 50$. http://s1070.photobucket.com/albums/u493/krwright0313/
i do my burn outs in 4wd |
05-19-2012, 06:14 PM | #15 |
Robert Olson Transport
IF you go with one of those plastic caps i have two pieces of advice.. make sure its glued down well... mine has popped off and in the heat it raises up in the center and also do not make any cuts on the thing until you determine exactly where your chrome strip sits... the guy who did mine messed up and theres a little section it falls short luckilly it is only where the passenger door closes
05-19-2012, 08:40 PM | #16 |
I am about to remove my plastic dash cap and put it in the trash. Mine makes my dash oversize and rubs against the door panels, and no matter how well it is glued down it still does not lay down flat. In fact, the manufacturer recommends just spot gluing it with silicone so that it will puff up and not get wavy in the heat. These plastic caps are one of the classic bad ideas in aftermarket products.
05-19-2012, 09:28 PM | #17 |
Were did you get yours from i heard good and bad about them..
