Old 05-15-2012, 10:06 PM   #1
BigRed76
BigRed76's Avatar
Is this the correct crossmember?
It appears to me that the current transmission crossmember on my '71 isn't the right one. The reason I think this is because the rear of the transmission seems really low, especially when you compare the angles of the transmission output and the driveshaft. So hopefully someone can confirm if this is indeed a correct auto trans. crossmember for a '67-'72.
I for sure know it's not the original crossmember since the truck used to be a three-on-the-tree truck. It also looks like the wrong transmission mount because I've never seen a round hockey puck style mount on these trucks.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 05-16-2012, 09:26 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Is this the correct crossmember?
No, that's the wrong crossmember.
The correct one is flat along the bottom and mounts inside the frame webs, not below it. They also have a wing on each side that goes up and mounts to the top of the frame rail too.
Image stolen from google...
Old 05-16-2012, 09:31 AM   #3
BigRed76
BigRed76's Avatar
Thanks for that picture. I had searched google but could only find top views of the crossmembers, which didnt help me. Do you have any opinion on aftermarket crossmembers vs. factory crossmembers?
Zach
Old 05-16-2012, 09:34 AM   #4
Tx Firefighter
I like factory ones myself. I have always felt that GM engineers know a lot more than most aftermarket engineers do. I like the way they tie the upper and lower frame sections together at an angle. It stiffens the frame a lot.
Old 05-16-2012, 09:53 AM   #5
68gmsee
Active Member
68gmsee's Avatar
Should be able to find one in a salvage yard just remember that they originally were riveted in and you have to cut the rivets or blow torch them off.
As low as that crossmember is, can you remount it on the upper part of the frame or maybe bolt it to the top section?
68gmsee is offline   Reply With Quote
Old 05-16-2012, 09:57 AM   #6
jjzepplin
jjzepplin's Avatar
Or put in longer bolts and some spacers to lift it up some?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 05-16-2012, 10:07 AM   #7
Tx Firefighter
Auto crossmember were bolted in. Only standards were riveted in.
Old 05-16-2012, 12:25 PM   #8
FirstOwner69
FirstOwner69's Avatar
Chevy072 has a couple for sale on the parts board.
http://67-72chevytrucks.com/vboard/s...d.php?t=521538
FirstOwner69 is online now   Reply With Quote
Old 07-17-2012, 09:44 PM   #9
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Subscribed. I think I have the same problem.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
