1970 Daily Driver
Drilled And Slotted Rotors for my 70, need advise
I am doing the D-52 rear disc brakes with Captain fabs brackets on my 70.
http://67-72chevytrucks.com/vboard/s...d.php?t=398352 I already updated the front end with a disc setup off of a 72. So I will have disc brakes on all four corners. I bought Napa rotors for a 92-02 Astro AWD safari (Part # 880442). But now I am thinking about going drilled and slotted rotors. Any recommendations on a good place to get matching drilled and slotted rotors for my truck that has the 72 truck rotors up front and the Astro rotors out back?
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
1970 Daily Driver
Re: Drilled And Slotted Rotors for my 70, need advise
I found these but they do not have the look I want. I would like to have the slot lines as well as drilled.
Fronts http://www.summitracing.com/parts/PW...600L/?rtype=10 $160 for the pair Rears (Astro Fronts) http://www.summitracing.com/parts/PW...622L/?rtype=10 $200 for the pair So to have them to my front door in 1 week it would cost me $372.90 Only problem is that they are drilled but not slotted. I am having a hard time finding a company that offers both the 71-72 style rotor and the 92-02 Astro style both that match.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. Last edited by lts70; 05-16-2012 at 02:02 PM. |
67-72 parts collector,…
![]() Join Date: Nov 2002
I know you want the look.
I put drilled and slotted rotors on the front of my blazer. They look cool when you first put them on. But later when all the drilled holes and slots start to rust, they look like crap. I will go with smooth plain rotors from now on,... unless I can find a rotor finish that won't eventually rust.
![]() ![]() Join Date: Jan 2011
Unless you're auto crossing or really pushing your truck, do you really need drilled and slotted rotors? I know, I like the look too .. but, just saying.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
1970 Daily Driver
It is for the looks that I am wanting them. I was planing on using some of the new rotor paint (Black) they have come out with latley to help them to keep there crisp look. I also have access to a sandblaster if I need to clean them up evey once in a while.
NAPA has this one for the 72 front but not anything similar for an astro that I would be useing on the rear. http://www.napaonline.com/Catalog/Ca...37L_0199484409
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. Last edited by lts70; 05-16-2012 at 02:50 PM. |
#6 | |
needs more $$$
It's funny because I've never thought about them rusting and always wanted them myself...I guess I've never noticed this on anyone's rides or they tend to clean them up before shows.
1970 2wd Blazer |
I get my rotors zinc washed at my local plater. Not expensive and lasts the life of the rotor. Only area that rusts is the pad contact area but gets shiny with a quick trip round the block.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
1970 Daily Driver
Here is some from ebay. Anyone delt with Power Sport brakes? They are claming made in USA. (EDIT Machined in USA)
Astro Link http://www.ebay.com/itm/CHEVY-ASTRO-...ht_3271wt_1398 72 C-10 (fronts) Link http://www.ebay.com/itm/CHECKER-CHEV...ht_4041wt_1398
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. Last edited by lts70; 05-16-2012 at 08:44 PM. |
Still plays with trucks
You could always have a machine shop turn a good quality American casting rotor into what you want. Not cheap but you will get what you want in the end and you can customize the look to the way you want them.
Biggest cost will be locating the cooling vanes and setting up a balanced drilling pattern to hit the voids between vanes. A little quality time with a good rotor and AutoCAD should do the trick. We used to do this in the machine shop I worked in back in the late 80's before the aftermarket stepped up and started making them. Now the only reason to have them made is for custom applications where no off the shelf drilled & slotted rotor exists like for this application. Maybe you can work up a deal with a local machine shop to make a few sets you can sell off to recover some of your setup costs.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Laid Back
![]() Join Date: Apr 2010
Buy zinc coated they won't rust!!!
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
I ordered a set of front rotors for my Nissan two weeks ago that the manufacturer(Power slot/Centric) is slotting for me, as they dont normally make slotted rotors for this application. So i know that custom can be done directly from the manufacturer. Price was very acceptable too.
This might be your easiest route to making sure that they match front and rear?? PM me if you are interested in the contact info that i have. |
#13 |
1970 Daily Driver
Anyone hear of SP Performance brakes? Looks like they have both applications and they are zinc coated. Links below
Astro van rotors http://www.topbrakes.com/carSeriesDe...ll+Wheel+Drive 72 rotors http://www.topbrakes.com/carSeriesDe...rear+2in.+shoe Posted via Mobile Device
#14 |
1970 Daily Driver
Missed these from summit the first time. A bit spendy though.
http://www.summitracing.com/parts/SS...UP&prefilter=1 http://www.summitracing.com/parts/SS...RO&prefilter=1 Posted via Mobile Device
#15 |
1970 Daily Driver
Anyone have any experience with any of these companies?
#16 |
A guy with a truck
Have you completed this upgrade? If you haven't bought yet, your last link, SSBC is known for quality products...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
