05-12-2003, 07:00 PM | #1 |
heater core keeps blowing out
I have a 72 gmc. The heater core keeps going out on it. I have been told that the pressure from the new water pumps blows the core out. I was also told to put a penny with a hole in the line.
Is there an electric heater that mounts under the dash that will work? It would also be nice to get rid of the ugly heater cover in the engine compartment. http://photos.yahoo.com/cruzn72@pacbell.net |
05-12-2003, 07:07 PM | #2 |
You can go with an aftermarket heater. I'm sure someone here can point you to some cool ones. As for pressure you can install a pressure regulator, but remember the flow is from the intake through the core to the pump.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
05-12-2003, 11:10 PM | #3 |
Something isn't right. It shouldn't blow out the heater core. I think I would look for the problem.
1968 Chevy - 292 with a powerglide |
05-12-2003, 11:13 PM | #4 |
its all about the +6 inches
Never heard of them blowing out.
Is there a chance that some one may be bending the 'pipe' on the intake and output on the core? I only say that becouse I blew out a couple that way. |
05-13-2003, 01:11 AM | #5 |
I put a 460 in my 77 f-150 4x4 and kept blowing heater cores, I think from that high volume water pump on it, I put a H pipe in between the two heater hoses that solved it, I used copper T fittings from plastic water lines in house plumbing,two T fittings with a small peice of hose in between, I really don't think they make heater cores like they use to.
05-13-2003, 02:00 AM | #6 |
former desert rat
Location: salt lake city, utah Home of the 3 M's Mormons, methlabs and minivans
It may be from electrolisys. Which is basicaly electricity currant in your cooling system. I have seen it happen a few times, where it actually weakens the solder joints inside the core. Try sticking the positive end of a voltmeter inside your radiator ( in contact with the coolant) when the truck is running and the neg. end to ground. If you get any readings, you have a grounding problem. Also, remember to do this with the engine cool, so you wont burn yourself when removing the rad. cap. Iam sure there are different methods and such, so this is mearly a suggestion. Good luck and let us know.
John
94 Chevy Silverado Ext cab 4/6 drop w/ 18's and 2500watt system (work truck). 67 Chevy swb under const. frame off custom, 20's, bagged and a large rat under the hood,and a 1940 Chevy truck under const. |
05-13-2003, 02:36 AM | #7 |
I've seen aftermarket water pumps trash cheap heater cores. That's why I suggested a regulator. Either that or get a better heater core (there's probably one that goes with the pressure output on the pump, not to mention a radiator). Typically if you go high pressure on one thing then everything else has to follow suit in the cooling system - especially if you get a high volume pump.
05-13-2003, 10:15 AM | #8 |
cobalt that reminds me when I put that 460 in with the high volume water pump, it only had a two core radiator, which I think couldn't take the water volume, so the pressure would build up, my theory anyway
05-13-2003, 10:22 AM | #9 |
Seņor Member
Hoses backwards? As COBALT pointed out, the flow is away from the core to the pump.
As for an electric heater the "big two" aftermarket air places have one, but they say it's intended to be auxiliary, not the main heat source. Kenneth
05-13-2003, 05:26 PM | #10 |
Thanks for the info
I appreciate all of the information. I think I will just plug off the lines and drive it in the spring and summer.
05-14-2003, 02:51 AM | #11 |
I did that once when mine blew, I just routed the top hose back into the water pump
