Old 05-16-2012, 05:45 PM   #1
SBTork
Garage wrench
SBTork's Avatar
Air leak.....what to do next?
I am having some issues fixing an air leak in my system. My system currently consists of an air tank, 4 bags, and manual paddle valves for each bag along with two dual needle gauges. For now the compressor is not wired up but should be later today.
I have a fill valve on the tank and one line going from that to the paddle valve switch panel where it t's to two t's, one for each bag. My LF bag seems to want to leak down to nearly nothing after about 2 days. Last time I tracked it, it leaked down 2 lbs in 2 hours. So far, I've switched out the air bag itself with a new one and also replaced the paddle valve. I think the only other thing I can replace is the air line itself, but as with everything else i've done, I am not sure that's it. The fitting on the bag has good quality thread sealer on it, it's tight, all the lines are tight in their fittings.....
I am not sure what else I can do other than replace the line and see what happens. Anyone have any ideas?
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 05-16-2012, 06:42 PM   #2
Pro Performance
Pro Performance's Avatar
Re: Air leak.....what to do next?
You might have tried this, but use soapy water to spray on all connections to track down the leak. If air is leaking, it will start to bubble. This is a good place to start, and should help track down the leak.
For threaded fittings, Loctite 545 is excellent for sealing the threads.
-Travis
Pro Performance is offline   Reply With Quote
Old 05-16-2012, 06:54 PM   #3
SBTork
Garage wrench
SBTork's Avatar
Thanks for the insight. I did use loctite 545 on all the fittings per my research on this forum. Looks like I will have to try the soapy water on the air line to see what's going on.
-Adam
Old 05-16-2012, 07:33 PM   #4
PBFAB.COM
PBFAB.COM's Avatar
A major leak spot is the actual end of the airline itself. If you remove the airline from a PTC ( push to connect ) style fitting, then you'll need to trim the end of the hose off after each use. If you look closely at the last portion of the air line, ( say up 1/4" when using 1/4" hose ), you'll notice some small "teeth" impressions in the hose where the fitting sealed down upon it last time it was inflated. Well if the "teeth" don't like back up then it will slowly leak out there. Be sure to trim the end fresh, and square, each time you go to re-insert the airline. Also make sure it's firmly seated into the fitting each time as well.
Another point to remember is that once you get a fitting tight, don't try to back it off slightly or, retighten more. Tighten the fitting to it's final resting point and leave it. If you tighten it, and then back it off 1/4 turn to line up, you've also back off the treat sealant slightly.
Also be sure to check the actual barb fitting on the back of the paddle switch. It can leak there, especially if you use a razor to cut the old airline off and might have put a slight nick in the actual barb, causing air to seep by thru that nick.
No matter what, grab the soapy water and see if you can source the leak. Spray it around every location where the airline has a fitting connection, as well at the component the airline is connected to.
Good luck.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 05-17-2012, 08:03 AM   #5
502ms
502ms's Avatar
Great info
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 05-17-2012, 11:55 AM   #6
PBFAB.COM
PBFAB.COM's Avatar
Originally Posted by 502ms View Post
Great info
Hope it helps anyone with an air leak.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 05-18-2012, 01:07 PM   #7
DLOE65
DLOE65's Avatar
Spray some soapy water in the paddle side too, if your paddles are old I have seen them leak internally.
DLOE65 is offline   Reply With Quote
Old 05-18-2012, 05:45 PM   #8
SBTork
Garage wrench
SBTork's Avatar
Good luck.
Excellent advice!! I got it fixed thanks to your advice. I had seen the "teeth" imprint on the line before and never thought twice about it. I re-cut all the lines that I messed with and it's good to go now. That and I got my 380C compressor wired up last night and everything works as it should. Thanks again for the help, MUCH appriciated!!
PB RULES!!!
-Adam
Old 05-18-2012, 05:54 PM   #9
PBFAB.COM
PBFAB.COM's Avatar
Porterbuilt - We aim to please and satisfaction is guarenteed !!
We're just glad that we were able to help you out with your problem. High 5's all around . Now get out there and drive !!!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 05-18-2012, 05:57 PM   #10
SBTork
Garage wrench
SBTork's Avatar
That's the plan, there is a car show about an hour away from me tomorrow and I am planning on hitting it up! Thanks again!
-Adam
Old 04-03-2013, 03:17 PM   #11
91Subbed
Any pics of your set up?
91Subbed is offline   Reply With Quote
Old 05-28-2013, 06:38 PM   #12
JCampbell
Bump.
JCampbell is offline   Reply With Quote
Old 05-28-2013, 06:58 PM   #13
91Subbed
What's the "bump" for?
Old 05-29-2013, 01:21 PM   #14
slosteve
'cuz we want pictures!
slosteve is offline   Reply With Quote
