Old 05-16-2012, 07:29 PM   #1
dhughins
dhughins's Avatar
anyone have ideas how to tighten castlenut onto ball joint?
I've been doing a front disc brake swap from ECE since last Friday. I'm having problems with the driver's side Castle nut that tightens onto the ball joint. I got the nut started but the ball joint stud spins with it. We tried jacking up the control arm until it lifted the truck off the jack, thinking that would put enough weight on the ball joint. no luck. I've tried setting the truck down with weight on wheels and that had the opposite effect(the ball joint space opened up). Any ideas?
i really don't wanna have to replace the ball joint. right now.
dhughins is offline   Reply With Quote
Old 05-16-2012, 08:02 PM   #2
JimKshortstep4x4
Re: anyone have ideas how to tighten castlenut onto ball joint?
Make sure both tapers are clean and dry. Clean the threads or better yet chase them on both the nut and ball joint, assemble the ball joint to the spindle and put some grease on the external threads. If it won't tighten with a wrench spin it with an impact gun. This has always worked for me.
Good luck,
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 05-16-2012, 08:19 PM   #3
SS Tim
SS Tim's Avatar
Just to be clear here. Is the nut cross threaded as in it won't go on or off now? Was the ball joint stud worn and shiny? If you are not sure take a look at the spindle you removed. The stud should lock in the taper on the spindle, are these new or used spindles?
If the threads are damaged try a thread file and do as little damage as possible. Sound like your ball joint is kind of shot as it is. Does the stud flop/rotate freely? If there is no preload its toast.
SS Tim is offline   Reply With Quote
Old 05-17-2012, 02:12 PM   #4
tubbedII
needs more $$$
tubbedII's Avatar
Even though the impact would probably be the only thing that would work in this case (given the threads are clean), you should really just replace the BJ. If it has enough play to spin, then it's just a good idea to replace now since it's apart..
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 05-17-2012, 02:40 PM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
You can put a pickle fork in there and use it to jam the ball joint till the nuts tight
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 05-17-2012, 03:23 PM   #6
ulakovic22
Aren't the ball joints used for drum brake spindles different than disk brake spindles? If so, do you have new correct ball joints? I thought I remembered something about the taper being different as well as the length, but I could be wrong, I'm still a newb on these trucks.
ulakovic22 is offline   Reply With Quote
Old 05-17-2012, 04:14 PM   #7
dhughins
dhughins's Avatar
I ordered a kit from Early Classic that uses the stock ball joint.
My ball joints don't flop around but it does spin while trying to tighten the castle nut.
On the passenger side we used a puller to push the 2 together, gonna try it on this side tomorrow.
Old 05-19-2012, 07:34 PM   #8
dhughins
dhughins's Avatar
Used the pulled to push it together and finally got done.
