Old 05-16-2012, 07:55 PM   #1
danny6892002
danny6892002's Avatar
Help with lights!!
I need help!!!! Am having trouble with the brake lights, if I press on the brake pedal both lights come on but when I use the passenger blinker the driver side brake light turns off. I just don’t understand why. If I turn my headlights both blinkers work fine. The only problem is when I press the brake and only when I use the passenger side blinker, if I press the brake and use the blinker to make a left turn my lights work perfect.
danny6892002 is offline   Reply With Quote
Old 05-16-2012, 08:14 PM   #2
Andy4639
Old member
Andy4639's Avatar
Wink Re: Help with lights!!
Check the rear housing and make sure it's grounded good.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 05-16-2012, 09:29 PM   #3
danny6892002
I did all of that, the light works but not when i hit the brake and use the right turn signal at the same time it left brake light wount turn on.
Old 05-16-2012, 09:42 PM   #4
Andy4639
Old member
Andy4639's Avatar
Question Re: Help with lights!!
Check the connector under the dash make sure it's ok.The brake signal if I remeber right goes through the turn signal so it feeds up to the steering wheel and then back down. You may have to pull the wheel and see if the turn signal is bad. Inside column.
Old 05-16-2012, 10:02 PM   #5
danny6892002
It’s just irritating the turn signals work fine with the headlights on and off the problem is only when I step on the brake and I use the right turn signal my left brake light turns off.
Old 05-16-2012, 11:31 PM   #6
GMCMAX
Active Member
GMCMAX's Avatar
Turn signal switch most likely, contact inside bad or dirty, might need a good cleaning. Had one the contact melted into the plastic, same symptoms....
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
