Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 05-16-2012, 10:23 PM   #1
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Stock Speaker Replacement
Anybody replaced a funky stock speaker under the dash grille?
I just don't have the "juice" to do the whole stereo thing right now, so I'm replacing the stock
radio with another stocker that works. Unfortunately, it won't work with a blown out speaker.
Any tips on a replacement would be appreciated.
I *almost* finished under the hood today (altho the hood's actually off...).
Front bumper (also *almost*) on. Missing three of the ss covered bolts. Ordered 'em.
I'm finally headed into the cab to start replacing stuff tomorrow.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 05-16-2012, 10:47 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Stock Speaker Replacement
Check this thread out...
http://67-72chevytrucks.com/vboard/s...d.php?t=524354
LockDoc
Leon
Old 05-16-2012, 11:00 PM   #3
magwakeenercew2jh
Originally Posted by LockDoc View Post
Thanks so much....
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 05-17-2012, 08:28 AM   #4
red69ss
Burnouts are therapeutic
red69ss's Avatar
I ordered one of the "stock replacement" ones and put it in my truck last week. I had to flip the bracket it came with and do a lot of bending to get it to fit right. It diffenently wasn't a direct bolt in but not too bad, I got it from the truck shop for about $35 and the sound is decent.
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 05-17-2012, 09:54 AM   #5
lil hoodlum
lil hoodlum's Avatar
I had to "flip" the bracket it came with as well. I drilled another hole instead of bending the bracket.
Keith
lil hoodlum is offline   Reply With Quote
Old 05-17-2012, 11:05 AM   #6
BruthaMan
US Army Veteran
BruthaMan's Avatar
Some pics from my ongoing DD build, using Boston Acoustics 3.5s (probably could have used 4"):
6.5's in speaker pods:
BruthaMan is offline   Reply With Quote
Old 05-17-2012, 01:50 PM   #7
WETOWM
If you just need your original reconed call jackson speaker service $50.00 he will do a real nice job
WETOWM is offline   Reply With Quote
Old 05-30-2012, 05:53 PM   #8
utee05
Where did you get the 6.5" speaker pods from? I was thinking of making my own kick panels but if the cost isn't that much I may look to just buy some.
utee05 is offline   Reply With Quote
Old 05-31-2012, 12:38 AM   #9
BruthaMan
US Army Veteran
BruthaMan's Avatar
I don't recall the vendor, off hand. Most of the truck part vendors carry these. I recall reading a post somewhere here that one company makes these and most of the truck part vendors that carry the speaker pods get from that one source.
You will have to trim these on the tops for the AC or heater vent areas. It wasn't a big deal. Dremmel tool helps make the job easy.
Old 05-31-2012, 09:05 AM   #10
jamesi20
jamesi20's Avatar
look here http://www.turnswitch.com/speakers.htm
Note: Many replacement speakers now sold by the discount stores, auto parts stores and mail order restoration parts houses are labeled as "4 to 8 ohm compatible" and are in fact 4 ohm speakers. These speakers can damage the older transistor radios. 4 ohm speakers will measure around 3.2 ohms with a DC ohmmeter. An 8 - 10 ohm speaker will measure around 7.4 ohms with a DC ohmmeter. The DC resistance is the critical number for the Delco radios as the output transistor is in series with the speaker. A properly operating Delco radio should have 1.5 volts DC across the speaker voice coil. A 4 ohm speaker will draw twice the current of an 8 ohm and cause the amplifier transistor (the half dollar size device mounted to the black finned heat sink on the back of a Delco radio) to run very hot.
jamesi20 is offline   Reply With Quote
