05-17-2012, 09:36 AM | #1 |
wont crank?
well it has happen to me twice in a week so am driving and turn it off at a gas station and wen i go in to turn it on i hear it like it "wanted" to crank just for mayb 1 sec l hear it like the starter lock? so i sit there for a couple of min and wont crank i check the battery and was fine good horn and lights everything was ok just wont crank i call my bro and we tow it home and guees what wen i got home it start working again am thinkin the starter is goin bad? a mecanic said it could b the switch. but i relly dont think it is the switch any of u guys had this problem
05-17-2012, 09:53 AM | #2 |
Getting Old; Going Broke
Re: wont crank?
Well, possible on both accounts really. If you have some lose, corroded or about to fall apart wiring it could do that. Or if you starter is on its way out it could do the same thing.
Ever done the old hammer trick on the starter? Have someone in the truck bumping the key over and over while another taps on the starter with a hammer. Very scientific I know, but its got me home more than once. As far as wiring issue, that could be anywhere between the key cylinder to the starter itself. Could also be the ignition itself. Heck it could be a handful of other things as well, but I'd start with simpler stuff first.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
05-17-2012, 10:10 AM | #3 |
Re: wont crank?
Bad ground.
I had the same problem. It would crank fine most of the time, then randomly not want to turn over at all...along with some other strange electrical issues. I added a ground strap from the factory battery ground point to the frame....no more problems Posted via Mobile Device
1985 Chevrolet K-10, SWB, 350/700r4, 6" Lift, 35" tires |
05-17-2012, 10:23 AM | #4 | |
Re: wont crank?
05-17-2012, 10:24 AM | #5 | |
Re: wont crank?
05-17-2012, 01:11 PM | #6 |
Robert Olson Transport
Re: wont crank?
it doesnt have to be a hammer.. a old fashioned j handle from the factory works as well
05-17-2012, 01:35 PM | #7 |
Re: wont crank?
well i check the grounds and its alredy bloted to the frame and the truck hasnt stop workin guess ill keep the hammer in the truck just incase it acts out on me again then ill just hammer the hole truck lol nahh just hope it dies fast to fix these
05-17-2012, 03:44 PM | #8 |
Re: wont crank?
Check the Neutral saftey switch on the colum mine does that sometimes won't crank and I have to put it in gear and back in park a few times
Posted via Mobile Device |
05-17-2012, 04:16 PM | #9 |
Re: wont crank?
Is your truck carb or fuel injection? I had an issue just like that with the carb vapor locking. It would start only after it cooled down a bit. I've also had bad starters do the same thing. Like stated before... it could be a number of things.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
05-17-2012, 04:40 PM | #10 |
Re: wont crank?
My truck has been doing this for weeks. I just turned the switch off and on til it would finally start. Dropped the starter and took it in today for testing and it was the solenoid.
$20 @ advance auto parts with limited life time warranty
05-17-2012, 05:10 PM | #11 |
Re: wont crank?
The pinion might of stuck in the ring gear and then after you jolted it around a little it popped out. That happened to me once and has never happened again since.
05-20-2012, 12:00 AM | #12 |
Re: wont crank?
Mine was dping this similar thing it turns out the wires from the starter were exposed and were scraching on the manifold just went ahead and replaced the wires and made sure they were nowear near any metal that would make it short out again
