Old 05-17-2012, 06:25 PM   #1
powerT
Brake pedal going to the floor
Brake pedal is going to the floor , it not touching the floor but it feels likes its going to . The brakes still stop , is the normal for these trucks or is the master cylinder or booster going bad ?
How can you tell if its the booster or master cylinder?
powerT is offline   Reply With Quote
Old 05-17-2012, 07:57 PM   #2
J Knight
J Knight's Avatar
Re: Brake pedal going to the floor
Sounds like your master cylinder is going bad, if so you may see some brake fluid leaking where.it mounts to the brake booster. You may also want to check all brake lines, calipers and wheel cylinders for leaks. When the booster goes bad the petal is hard to push like when the engine is turned off.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 05-17-2012, 08:38 PM   #3
coltonk
coltonk's Avatar
Did you just recently replace brakes?
"How does a posi-trac work on a Plymouth?.. it just does!"
coltonk is offline   Reply With Quote
Old 05-17-2012, 08:42 PM   #4
Goldfinger
Goldfinger's Avatar
Make sure they are bled. if not worn pads/shoes. then check the master cylinder. I think there are 2 chambered so if you were on 1 and it fails it could cause this.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 05-17-2012, 08:53 PM   #5
powerT
Yes i put new brakes and rotors on , tried to bleed but one of the bleeders is broke off
Old 05-18-2012, 01:34 AM   #6
84_chevy
you need to replace the bleeder or get a new caliper, once you bleed the lines I'm sure your problem will disappear.
84_chevy is offline   Reply With Quote
