Old 05-17-2012, 06:26 PM   #1
Touchdown67
Touchdown67's Avatar
Engine temperature gauge
I have a 65 C10 with factory gauges and a SB400 engine. The problem I am having is the temp gauge goes to almost full hot after about 5 mins run time. I have gone through everything (ie. radiator, water pump) I put in a 195 degree thermostat instead of the 160 it had before. We have checked the temps on all the hoses and the water neck with a temp gun and the temps seem to be between 171- 195 degrees. I bought another sending unit from NAPA and the gauge still shows hot. I am wondering if there is a different sending unit I should be looking for or is the gauge shot. Has anyone encountered the same?
Touchdown67 is offline   Reply With Quote
Old 05-18-2012, 04:51 AM   #2
spacedebris
Re: Engine temperature gauge
I've never fooled around with the vintage gauges personally. However I did have the same kind of problem with my 89 GMC Jimmy with the temp gauge reading over 240 when the temp gun indicated only 205. In my case it was a bad resistor on my gauge. At the time I was in school for electronic engineering and instead of just buying a new gauge, I replaced the resistor (cost me 95 cents from radio shack), then checked again. gauge read between 205-210 when the heat gun said 205.
Now granted this was with a system over 2 decades later but the older gauges are likely built in the same way, sender sends a signal to the gauge and the reading across the resistors determines how high the needle goes. Since you said you replaced the sending unit, this would be my best guess.
spacedebris is offline   Reply With Quote
Old 05-18-2012, 10:20 AM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
I’m wondering if you have the correct sender for gauges. According to the offerings at Classic Parts, there’s one sender for gauges and a different part for idiot lights. If you’re running the off/on type for lights that might produce the full hot reading. Here’s a photo and link for the gauge sender, followed by the sender for the lights. Also make sure you have no teflon tape on the sender threads which can insulate the circuit and ruin the reading.
http://www.classicparts.com/1956-72-...ctinfo/53-811/
http://www.classicparts.com/1961-66-...ctinfo/53-812/
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-18-2012, 10:23 AM   #4
MikeN
MikeN's Avatar
I had the same problem with the factory temp gauges on both my 64 C10 and my 69 Chevelle. The parts houses sell sending units that are supposed to fit a variety of applications, and they don't work right. I got the proper sending units for both cars from these guys, and both gauges now work perfectly.
http://www.lectriclimited.com/
MikeN is offline   Reply With Quote
Old 05-18-2012, 02:06 PM   #5
m455sx
m455sx's Avatar
Yep i have bought several one from napa and one AC delco as well and mine saying it is running hot. Mine is at the very edge of the green line.
1970 442 convertible
1970 Cutlass SX
1962 Chevy Stepside
2011 GMC 3500HD Crewcab SLT DRW
m455sx is offline   Reply With Quote
Old 05-18-2012, 02:08 PM   #6
m455sx
m455sx's Avatar
Here is my mark for 180 degrees. I used my digital heat sensing gun at the thermostat and sending unit.
1970 Cutlass SX
1962 Chevy Stepside
Old 05-18-2012, 02:16 PM   #7
ChevySixty6
ChevySixty6's Avatar
Well i finally got off my butt and ordered one of these. With shipping it was only $34. I've read several posts in the past about getting the correct temp gauge, but never got " a round to it". It was always one of those " i should probably get one of those". Now i won't have to keep second guessing myself and wondering is it really too hot, or just the gauge.
Members i've met: LiLRed66
ChevySixty6 is offline   Reply With Quote
Old 05-22-2012, 11:51 AM   #8
Touchdown67
Thank you MikeN... I ordered a sending unit and a horn relay from these guys today.
Old 05-22-2012, 11:55 AM   #9
m455sx
m455sx's Avatar
let me know if that fixes the problem, if so i will buy one.
1970 Cutlass SX
1962 Chevy Stepside
Old 07-17-2012, 01:14 AM   #10
amccomb
I dont have a issue with the guage reading to hot. Mine doesnt work at all. When I turn the key on the guage needle moves. But it doesn't work after that, I replaced the sending unit with one from napa, still nothing. Any suggestions?
amccomb is offline   Reply With Quote
Old 07-17-2012, 02:17 AM   #11
Touchdown67
Well I put the sender in a few weeks ago with teflon tape and it seems to be reading more accurately. I might pull it back out and remove the teflon tape and see if this makes any difference. But overall it seems to be more accurate. I also bought a horn relay from Lectric and now I have a working horn. Good luck....
Old 07-17-2012, 08:28 AM   #12
1963c-10
1963c-10's Avatar
Probably the guage. Is it a factory guage? If so PM me, I have a couple.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 07-18-2012, 06:06 PM   #13
sandmerchant
sandmerchant's Avatar
I have the same problem on my 64' Suburban 4x4 with a 350. Gauge shows hot when on freeway- right at the end of the green. If it's a hot day, the needle will just start to touch the white line below hot.
This is the temp when running around town.
Because it seemed to only get hot when running high RPM's I thought it might be caused by my lower radiator hose collapsing, but the hose is fine.
Heat gun shows around 180 at the block freeze plugs, the heads run about 5 degrees higher.
I replace the sender twice- once from Napa and once from Brothers, still the same problem.
I never thought about the Teflon tape concern, I will check and remove if I applied it.
If not, I will buy one from the link.
sandmerchant is offline   Reply With Quote
Old 07-18-2012, 08:18 PM   #14
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I have this issue with my 61 and I read somewhere the auto parts store senders will not work right. Someone posted a GM part number that is correct for these guages. I dont have the number handy and have not bought one myself yet, but would like too.
I also have a mechanical guage under the dash that works fine so Im good for now and I know im not over heating.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 07-18-2012, 10:08 PM   #15
Greg63
Enjoy your truck
Greg63's Avatar
I was told years ago not to put anything on the threads of the sending unit as it interferes with the grounding of the sender and will affect the gauge reading.
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 07-19-2012, 08:42 AM   #16
Breadstick
Greg.
I was doing some research on this recently and read this a lot of places, as well.
Breadstick is offline   Reply With Quote
Old 07-19-2012, 11:26 AM   #17
creep
Registered Loser
creep's Avatar
I put in a sending unit from classicparts and it read really hot so I installed a gauge directly on the motor and it turned out that my motor was actually running hot. After a rad and fan change the motor stays between 180-190 according to the motor mounted gauge and the dash gauge stays right around the middle.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 05-17-2017, 04:27 PM   #18
dylan1970
dylan1970's Avatar
Has anyone found a sensor for stock gauges that is a 3/8 X18NPT?
dylan1970 is offline   Reply With Quote
Old 05-17-2017, 04:40 PM   #19
The Rocknrod
Moderator
The Rocknrod's Avatar
https://www.lectriclimited.com/faq/
The correct one: https://www.lectriclimited.com/elect...ing-unit-86912
Some info: http://67-72chevytrucks.com/vboard/s...d.php?t=587190
Found in the FAQ section: http://67-72chevytrucks.com/vboard/s...d.php?t=646002
Old 05-17-2017, 05:55 PM   #20
vince1
Internet type in 3/8 NPT heat sensor. Summit sells them.
vince1 is offline   Reply With Quote
Old 05-17-2017, 05:56 PM   #21
shp4man
shp4man's Avatar
An in line resistor will fix the issue. My truck took about a 13 ohm one.
Everybody has to believe in something. I believe I'll have another beer.
shp4man is offline   Reply With Quote
Old 06-15-2018, 05:03 PM   #22
sixty4bigwindow
sixty4bigwindow's Avatar
Reviving this thread.. I have a sensor in my 64 that is from an equus temp gauge, (buddy had the gauge, didn't need the sensor.) Same issue, wired right to the stock gauge, buries on hot.
So if I throw a 13 ohm inline resistor, this should fix my issue of not reading right?
Been a crazy 2018. Moved twice, back HOME in Oregon. Now to put everything back together, including the truck...
My build thread for "Rocket" - http://67-72chevytrucks.com/vboard/s...d.php?t=753023
sixty4bigwindow is offline   Reply With Quote
Old 06-16-2018, 01:32 AM   #23
Captainfab
60-66 Nut
Why not just get the correct sending unit for your factory temp gauge?
Old 06-16-2018, 08:35 AM   #24
The Rocknrod
Moderator
https://www.lectriclimited.com/vehic...del/56?cat=734
Temperature Sending Unit $25.00
Part #: 01513321
-original 1/2 x 14 N.P.T.F.-, with factory gauges (correct resistance and connection, produces accurate gauge display) more information
Temperature Sending Unit $34.00
Part #: 01993561
-original 1/2 x 14 N.P.T.F.-, with warning lights Note: Requires a double 56 series female terminal connection more information
Old 06-16-2018, 02:38 PM   #25
sixty4bigwindow
Because that would just be too easy lol! Thanks for the links. I am still learning about engines and making things work correctly. I just wasnt sure if it was the sender or the gauge. This makes more sense!
