back brake bleeder may be stripped
was going to bleed the brakes but it looks like the previous owner stripped both of the back bleeders. Any idea how to fix this problem ?
im not sure when the last time the bleeders where turned |
Re: back brake bleeder may be stripped
sounds like you're gonna have to replace the wheel cylinders
What he said ^ if you go replace them, it would be a good idea to get a hardware kit for the breaks. Hope ya get back up and running soon
![]() Posted via Mobile Device |
Robert Olson Transport
![]() Join Date: Oct 2002
ive had success with a vise grip but in all likelyhood you will be replacing the wheel cylinders soon
That's how I ended up doing a complete brake job lines and all. It started with a couple rusty break bleeders, who of thought that.
Good luck :P |
After i replace the wheel cylinders what wrench do you all use on the bleeders there in btween a couple of bolts (maybe an off set wrench )
78K & 79C Jimmys
soak them with penatrating oil...PB blaster works good
I have a almost foot long skinny wrench 1/4 an 5/16,just for those sometimes they loosen wiggling vise gripes back and forth,sometimes they snap good luck!
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
I have good success using kroil penetrating oil. The use a brake bleeding wrench. They are double box end 6pt wrenches. But good luck they have a tendency to snap off when they are frozen. Use the same oil if you have to replace they cylinders but use a line wrench for the brake line.lineup
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
back in the day we used to call them line wrenches.. they have a smaller opening and they grab more sides of the bolt making it harder to strip. I forgot to mention spray the heck outta it with penetrating oil
Moderator
![]() Join Date: Oct 2008
I'd replace the wheel cylinders. They're usually less than $20 for a pair. The bleeder threads seize from both ends because the rubber bleeder caps are always missing letting salty winter water get inside the bleeder.
Usually the short steel axle brake lines give me fits at the wheel cylinders. I just assume I need to replace them. They are a fairly cheap short run to the brass tee fitting on the end of the rubber frame to axle line above the pumpkin. Cut the steel lines off close to their fitting leaving the hex sticking out of the tee. Then you can unscrew the stubs from the tee with a snug fitting 6 point socket. Spray the crap out of them with PB Blaster the night before you get started. I push the new fittings back from the flare and wipe a thin layer of never-seeze on the steel line and on the threads as well as the bleeders. Rubber bleeder caps are cheap. I check em as part of my PM routine every 5K or so just to be sure they are present.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#11 | |
I believe it was 5/16", but you'll have to check for sure. A standard wrench will fit. I just tighten them back down with the socket, then I don't round off the new bleeders.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ![]() I'm kinda like duct tape- no real purpose, but handy to have around. |
