Old 05-18-2012, 02:23 AM   #1
Beat68CST
Beat68CST's Avatar
67-68 Grill help
It's been about 3 years since I took the grill off my 68, sad, I know.
Now since I got my intercooler and stuff mounted, how does that tapered "pan" bolt to the grill and core support.
It like a very wide triangle, what I need to know is which side it top or bottom and whether or not I really "need" it.
Beat68CST is offline   Reply With Quote
Old 05-18-2012, 04:24 AM   #2
oldspowered67C10
Re: 67-68 Grill help
It bolts up so that the bolts that hold it to the rad support have to be tightened from the bottom. It then bolts to the bottom side of the grille.
Im sure if you left it out the front end would be structurally fine, Id be concerned about cooling air flow.
oldspowered67C10 is offline   Reply With Quote
Old 05-18-2012, 10:50 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Check out the first picture in this thread. It took a while to load on my computer but your mileage may vary...
http://67-72chevytrucks.com/vboard/s...d.php?t=427792
LockDoc
Leon
Old 05-18-2012, 11:48 AM   #4
67chevy1series
67chevy1series's Avatar
not really needed and it would be structurally fine but it does keep it a little cleaner up front from road dirt. just undercoat the bottom and you should be good it will keep the back of your grill clean, it might even help keep the fron clean a little... ( if dirt comes from behind the grill and goes through one of the openings and gets on the outside) but thats my 2 cents
67chevy1series is offline   Reply With Quote
Old 05-18-2012, 12:08 PM   #5
Beat68CST
Beat68CST's Avatar
Thank you gentlemen, especially Leon for finding a picture!
Definitely appreciate it, now time to go cut that up... yay
Old 05-18-2012, 06:11 PM   #6
67chevy1series
lmao... have fun!.... but not to much fun... wheres the build thread???????
Old 05-21-2012, 01:56 PM   #7
Beat68CST
Beat68CST's Avatar
Build thread...
Uhh, Dieselwrencher asked the same thing!
