Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-18-2012, 11:08 AM   #1
pockets
pockets's Avatar
Securing battery
So I was looking through the 2012 NHRA rule book regarding batteries and it if I read it correctly it says that you can use an OEM tray/mount. If you move it, then all kinds of other rules apply about bolt size, box type, etc.
My truck is a daily driver so I'm not really keen on moving the battery to the bed, but the factory hold down rubber "clamp" doesn't seem like it would pass tech. Anybody have anything under the hood other than stock mount?
The truck hasn't been down the strip yet, but on paper would be in the high 12's. I could fab something up with bolts and metal hold down, but just wanted to see if anybody had some other ideas.
Project Bad Karma
pockets is offline   Reply With Quote
Old 05-18-2012, 01:50 PM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: Securing battery
i relocated mine to the rear of the bed and installed box from jegs
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 05-18-2012, 04:06 PM   #3
Marv D
Registered Truck Offender
Marv D's Avatar
If it's the 'stock / factory' hold down,, it will pass. Once you cross the 11.99 threshold they start getting more particular on what is 'stock and what is not.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 05-18-2012, 04:13 PM   #4
pockets
pockets's Avatar
That's good. The only way I'm getting that low is if I spray it and I don't plan on doing that. Thanks.
Project Bad Karma
